markal49
15kHow many miles does it have? The first couple of thousand miles mine was shifting a little oddly, but now it's mellowed out at 7k.
I bought our new '24 STX Ranger in mid-March. It's at about 2,000 miles now and I've noticed some hard upshifts and downshifts in the lower gears. Perhaps that will smooth out with more miles but it doesn't give me a lot of confidence in the transmission.How many miles does it have? The first couple of thousand miles mine was shifting a little oddly, but now it's mellowed out at 7k.
That is how mine started. Then it goes to floating before it finds a gear. Then it starts missing gears. Then you need a tow truck. I would change your fluid and filter right now to try and abate the damage. If you catch it before you have damage, you can get a kit from https://nextgendiesel.com/collections/ford-transmissions-transmission-parts that upgrades the parts that start the cascade of failures. But if you already have symptoms, it may be too late for a kit.I bought our new '24 STX Ranger in mid-March. It's at about 2,000 miles now and I've noticed some hard upshifts and downshifts in the lower gears. Perhaps that will smooth out with more miles but it doesn't give me a lot of confidence in the transmission.
That is interesting. What does Ford say about that? Shouldn't that be a warranty fix?That is how mine started. Then it goes to floating before it finds a gear. Then it starts missing gears. Then you need a tow truck. I would change your fluid and filter right now to try and abate the damage. If you catch it before you have damage, you can get a kit from https://nextgendiesel.com/collections/ford-transmissions-transmission-parts that upgrades the parts that start the cascade of failures. But if you already have symptoms, it may be too late for a kit.
LOL... good luck with that gimmicky electric motor stuck on the tranny, to try and improve mileage and reduce turbo lag, along with losing all of the under back seat storage area needed to house the battery for that motor.That's it. I'm trading my Ranger for a Taco.
Interesting. Have you installed this kit?That is how mine started. Then it goes to floating before it finds a gear. Then it starts missing gears. Then you need a tow truck. I would change your fluid and filter right now to try and abate the damage. If you catch it before you have damage, you can get a kit from https://nextgendiesel.com/collections/ford-transmissions-transmission-parts that upgrades the parts that start the cascade of failures. But if you already have symptoms, it may be too late for a kit.
This. If I listened to every clickbait doomsayer on social media I wouldn't: own anything, do anything, say anything, or eat anything.That being said, I am increasingly suspicious of these "experts" on YouTube raising alarms. I spent
I felt the same way. Bring it to the dealer with your concern, so that you have a paper trail. And hope that the truck smoothes out over time.I bought our new '24 STX Ranger in mid-March. It's at about 2,000 miles now and I've noticed some hard upshifts and downshifts in the lower gears. Perhaps that will smooth out with more miles but it doesn't give me a lot of confidence in the transmission.
Yeah, that's my plan. I'm going to try to get the oil changed at our most local Ford dealer and will raise the issue with their service manager. The shifting issues and the somewhat mushy brakes are my only mechanical complaints so far. But, don't get me started on the Sync4a...aye yi yi! ?I felt the same way. Bring it to the dealer with your concern, so that you have a paper trail. And hope that the truck smoothes out over time.
If you're implying that a manual transmission would somehow just be flawless, look at the new (4th gen) almighty, halo-donning, always reliable tacoma with the manual transmission:If they want to prevent this nonsense, the solution is simple:
A lever, a cable, and a reasonable number of gears. Problem solved. End of story. PERIOD.
I am planning to since I now have a new tranny. But I cannot find a reputable shop willing to do it. They say it is easy, but I am not about to do it myself.Interesting. Have you installed this kit?
