Expert Warns Of Major Flaws In Ford And GM 10-Speed Transmissions
Daweism
Austin, TX
Mine has a jerky 3rd to 4th shift in sport mode if driving at an incline but it doesn't bother me, I trade in every 3 to 4 years anyways.
Raptor-24
Kris
Asheville
2024 Raptor Ranger / ProCal Tune
Real Estate
My 23 Tremor with 19K miles, the drive shaft and assembly exploded at 15mph. Did some gnarly damage. The 1080R is having tons of issues. Traded that in after warranty work on a Raptor.
Leo
Casper, WY
20 F250 Lariat Tremor
This is a real deal. My 20 F250 transmission went out last month at 35,000 mi. Just after warranty expired. Bottom line is they are using cheap parts inside such as high porosity aluminum that is prone to failure. when valves start to leak, fluids are not in the right place and metal starts to enter circulation. Then everything starts to wear and break. Usually starts with the clutch drum. Mine was a catastrophic failure. This is in all the 10 speeds that GM and Ford developed jointly.
Gary Brantley
Cameron, Texas
2024 Ranger STX
How many miles does it have? The first couple of thousand miles mine was shifting a little oddly, but now it's mellowed out at 7k.
I bought our new '24 STX Ranger in mid-March. It's at about 2,000 miles now and I've noticed some hard upshifts and downshifts in the lower gears. Perhaps that will smooth out with more miles but it doesn't give me a lot of confidence in the transmission.
Leo
Casper, WY
That is how mine started. Then it goes to floating before it finds a gear. Then it starts missing gears. Then you need a tow truck. I would change your fluid and filter right now to try and abate the damage. If you catch it before you have damage, you can get a kit from https://nextgendiesel.com/collections/ford-transmissions-transmission-parts that upgrades the parts that start the cascade of failures. But if you already have symptoms, it may be too late for a kit.
Gary Brantley
Cameron, Texas
2024 Ranger STX
That is interesting. What does Ford say about that? Shouldn't that be a warranty fix?
sweeks888
Richland, WA
That's it. I'm trading my Ranger for a Taco.
LOL... good luck with that gimmicky electric motor stuck on the tranny, to try and improve mileage and reduce turbo lag, along with losing all of the under back seat storage area needed to house the battery for that motor. :)
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
Interesting. Have you installed this kit?
Boosted6G
PNW
2025 Vel Blue Raptor
That being said, I am increasingly suspicious of these "experts" on YouTube raising alarms. I spent
This. If I listened to every clickbait doomsayer on social media I wouldn't: own anything, do anything, say anything, or eat anything.
DutchRanger
Mark
Austin
24 ranger xlt fx4 2.7l
I felt the same way. Bring it to the dealer with your concern, so that you have a paper trail. And hope that the truck smoothes out over time.
Gary Brantley
Cameron, Texas
2024 Ranger STX
Yeah, that's my plan. I'm going to try to get the oil changed at our most local Ford dealer and will raise the issue with their service manager. The shifting issues and the somewhat mushy brakes are my only mechanical complaints so far. But, don't get me started on the Sync4a...aye yi yi! ?
If they want to prevent this nonsense, the solution is simple:
A lever, a cable, and a reasonable number of gears. Problem solved. End of story. PERIOD.
If you're implying that a manual transmission would somehow just be flawless, look at the new (4th gen) almighty, halo-donning, always reliable tacoma with the manual transmission:
https://www.tacomaworld.com/threads/manual-transmission-needs-replaced.829779/
...but I'm sure Ford would just knock it out of the park.
