F150-LED Grill Lights - 5 light kit fitment
RETMSG
Mike Dumas
Boaz, AL
2024 Ranger STX 4x4
Contractor
I know you’ve seen plenty but I wanted to share mine!
Ford Ranger F150-LED Grill Lights - 5 light kit fitment IMG_0922
Ford Ranger F150-LED Grill Lights - 5 light kit fitment IMG_0920
Dr. TJG DVM
Dr. TJG DVM
TJ
2025 Ranger 4x4 Lariat 2.7L
Veterinarian
Nobody has tried the 5 light set? No response from F150-LED, maybe I will have to DM them to get a response or picture :rolleyes:
GritzNGravy
Andrew
PNW
2025 Ranger XL 4x4
Mechanic
I just received the 5 light set but have not installed it yet. I test fitted them at the end grill slots that are shorter and curved and they do not fit. The sticky tape that holds them to the grill does not make contact with the curve in the end slots. Maybe with some modification to the grill they might work, but im not sure if i want to do that
Ford Ranger F150-LED Grill Lights - 5 light kit fitment processed-493F0134-F1ED-444E-AC00-E24B58439514
Ford Ranger F150-LED Grill Lights - 5 light kit fitment processed-95773EF5-1640-4EE4-8381-BBCB13676BA6
GritzNGravy
Andrew
PNW
2025 Ranger XL 4x4
Mechanic
I installed my 5 light kit today. I had to take a dremel to the end slots in the grill to get them to fit. The end lights are at a slight angle compared to the center ones. Only problem I had was that after I was done they didn't work. I used the f150led adapter that plugs into the fender light for power and I soldered and heat shrink a 2 pin connector onto the end of the kit and the adapter so I wouldn't have to use those tap in things it comes with. Anyway the black wire out of the adapter was positive and the red was negative so I re-soldered it with the black to red and red to black and it worked! I'm not that good with the dremel and im sure others can do better work than me on the end grill slots.
Ford Ranger F150-LED Grill Lights - 5 light kit fitment IMG_0486copy
Ford Ranger F150-LED Grill Lights - 5 light kit fitment IMG_0488
slots.
Dr. TJG DVM
Dr. TJG DVM
TJ
Veterinarian
slots.
Wow, that really sucks that they didn't check the fit before offering the 5 light kit. I really do like the look though. Thanks much for the reply. I will have to really think about whether it's worth potentially damaging the grill to make them work. I suppose the outer two could be moved in a space- similar to the post above with 4 lights in closer pairs.
natkill
OK
2026 Ranger Lariat 2.7L FX4, Marsh Gray
I think 3, 4, and 5 each look great in their own ways. That is a bummer though about the wonky fitment for the end two spots when doing 5 lights.
Has anyone done all 5 next to each other rather than spaced out? Kinda like this:
Ford Ranger F150-LED Grill Lights - 5 light kit fitment 1785868680853-xz
I'm waiting for someone to buy two kits so they have a total of 7 or 9 lights across. :LOL:
Ford Ranger F150-LED Grill Lights - 5 light kit fitment 1785868814470-yf
This looks like a perfect job for someone good with 3D printing: print a bracket that fits snugly into that end slot and is recessed on the front to accept the light. Anyone familiar with 3D printing thing this is doable?
Albanogc
Albano
Brazil
Ranger Black 4x2
I'm deciding which one to choose. 4 or 5.
If there’s any picture or tip, it would be really helpful.
Ford Ranger F150-LED Grill Lights - 5 light kit fitment 9A6F2702-8557-467C-B9B0-773237196E88
