Fog light options
BayouRaptor
Rob
louisiana
I am looking for a different set of fog lights for my raptor. I currently have the signature luxe fogs and while I like the output I think the quality is lacking. I am having the same issues as several other board members with the lenses magnifying sunlight and melting my shrouds and only having 2 mounting points causes the light to shake on rough terrain . I have seen videos of the DD ssc1 fog lights but I don’t feel like the output justifies the price.
I have seen other posters say they were able to get diode dynamics elite and ss3 to fit but I have not seen any concrete info and pictures of the mounts don’t look like they would line up. Are there any other known lights that will fit then Ranger raptor?
Bt_okst
BT
Ok/Colo
This is what I installed.
https://www.diodedynamics.com/ssc1-led-fog-light-kit-for-2024-2026-ford-ranger-raptor.html
Ive been very happy with them.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
I think your limited on options. I have the el series on my xlt fx4 from the 19-23's but looks like the RR mounts differently. where as the regular rangers use the same the fogs as last gen.
Ford Ranger Fog light options Screenshot_20260207_003313_Samsung Internet
Ford Ranger Fog light options Screenshot_20260207_003322_Samsung Internet
Ford Ranger Fog light options Screenshot_20260207_003356_Samsung Internet
Ford Ranger Fog light options Screenshot_20260207_003404_Samsung Internet
Diode on bottom, look at how bigger the dd heatsink is over the oem. lol
Ford Ranger Fog light options 20250614_112714
dd on top here with the plastic still on it. all mounts are the same
Ford Ranger Fog light options 20250614_112658
the RR you would be able to use 1 side 2 screws, might be able to cut and platic weld the other side mount in the correct spot, if the housing themselves will fit the opening
BayouRaptor
Rob
louisiana
This might be the answer then. I think I’m going to put the stock lights back in for now to stop the damage from getting worse
ryanO
Ryan
2025 RangerXLT
Sales
Do you have the elite series from DD installed? Whats the difference between type A and NA? I have a 2025 XLT and would love to install these if they fit.
ShadowDragon24
2025 Ranger XLT Fx4
Yupp. I installed the elite series ambers. I had pro ss3 fogs on my last rig, I wanted oem+ look. and while significantly better then the oem trash, I miss the performance of the ss3 pro.
the 19-23 fogs elite or ss3 kit will fit the 24+ direct swap. the part # on my 25's matches the 19-23 exactly.
Diode Dynamics Elite series. or SS3 max's the previous gen ranger fog lights fit. I am running a set of 5gen Elite's on my 25. I even have the amber back lighting hooked up to an ignition fuse for an extra drl. granted its not bright for daytime use. but its nice in the night.
ryanO
Ryan
2025 RangerXLT
Sales
Interesting. What is the "type A" vs "type NA" mean?
Are you saying the SS3 is better?
srv256ss
2025 Ford Ranger Raptor
Can you post a pic of the melting? Hadn’t heard this before this thread.
outdoorsman98
Joseph
New Jersey
I installed Baja s1’s and they’ve been awesome so far. Used Foxbeam bracket and spv parts adapter to make them plug and play with oem harness and switch
Ford Ranger Fog light options IMG_0630
BayouRaptor
Rob
louisiana
That’s what I’ve been looking for but I’m not sure if foxbeam closed or what because the website is gone and last time it was working they only had like 2 items listed. Hopefully they come back because this is what I’m looking for
BayouRaptor
Rob
louisiana
I can get you some pictures in the daylight tomorrow. I’ve seen a few other forum members with the same problem. My truck stays outside of the garage and the sunlight magnifies through the lenses and melts the plastic around the fog lights. The lights output is great but I don’t want it at the expense of damage to the truck
srv256ss
Please do, mine is inside at home and work. I imagine while moving it’s ok, it’s at rest that it’s a problem?
Roverhound
Walter
Fort Defiance, VA
Mechanic
Same here.
