Ford's Unpainted Drive Shafts
josephp732
Joe
NJ & FL
I just got a new 2025 Ranger Lariat, manufactured date is 4/1/2025...Hmmm an April fools day build.. great...anyway...the raw unpainted drive shaft kind of drives me nuts and since the truck is pretty new it doesn't have much surface rust yet. I was wondering if anyone has coated or painted the drive shaft in their Ranger? If so what product did you use?
Ya there's an older thread on rusty drive shafts. A few members did remove and paint them.
My Mustang differential also came unpainted. I painted it with Tremclad Satin black rust paint.
It still looks mint after 14 years. Rusty parts on a new vehicle really trigger my OCD tendencies.
I'll use it on the driveshaft assembly at some point.
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
This is known with the US assembled rangers. The ones assembled in Thailand all have painted drive shafts. Not sure why they don’t do it in the US?
A few days after I brought my Ranger home I coated the whole underside with lanolin undercoating, and I'll touch it up at each oil change.
Grand Nat
NYC-Long Island
Schwinn Sting Ray
I used the clear Cosmoline on the shafts. You can brush it on or spray it. It will have a slight amber color or you can use the Black Cosmoline. I use it on both vehicles. I go off road on sand by the salt water so I want the most protection for the undercarriage.
Ford Ranger Ford's Unpainted Drive Shafts Ranger st Beach
Ford Ranger Ford's Unpainted Drive Shafts MAV177
josephp732
josephp732
Joe
NJ & FL
Sweet looking truck!
josephp732
josephp732
Joe
NJ & FL
I am taking my truck in this week for a spray-in Rhino bedliner, has anyone thought about having a lite coating of bedliner material professional spayed on the drive shaft?
chasc
Illinois
2024 Ranger
I don’t have a lot of first hand drive shaft experience but I read often about issues when they become unbalanced. I personally would avoid adding anything to it to avoid affecting the balance. Even just spraying something on unless you’re continuously turning it while it dries the coating will creep due to gravity and be thinner on the top and thicker on the bottom. The thicker the coating (like bed liner) I’d think the higher the risk it produces a noticeable vibration.
jack the back end up and let it idle in drive while you spray so its even?
i have been worried about off balancing the driveshaft too because i used to do the balancing on turbine engine power turbine shafts and compressor assemblies and know first hand how a slight misbalance can cause them to frag out at high speed
josephp732
josephp732
Joe
NJ & FL
I was thinking the same thing. Just mask off the under side, lightly sand and clean and then slowly have the engine rotate the drive shaft and spay away. I found on an F150 forum that folks have had very good long term success with Por15: https://www.amazon.com/POR-15-46318-Safety-Yellow-Coat/dp/B00XKTVE4Y?ref_=ast_sto_dp_btp&th=1
