Raptortugal
Portugal
Ranger Raptor 6g
for some unknown reason my ranger does not keep memory of the drive mode when I shut off the engine (the default, as per manual, should be a pop up at re-start asking to confirm the previous drive mode, or resetting to normal). does anyone know if this is a simple parameter setting in forscan?
Same for me, at each start the "normal" mode is set by default. Does anyone know the forscan procedure?
Sequoia
Dan
Germany
Ranger Wildtrak 2023
What is there to fix if nothing is actually defective but working as intended? There simply is no coding to retain the DriveMode.
joordan
Italy
ranger wildtrak 2023
not according to the manual. the manual says that when you switch the engine off in any mode different than normal, at re-start there is a pop-up asking to keep the last mode or not.
that pop-up never comes on my ranger, so I always re-start default in normal mode
Sequoia
Dan
Germany
Can you show that from the manual? I can’t find that point in my manual.
Where is the pop-up supposed to appear? There is already one that asks about the interior monitoring of the alarm system.
Raptortugal
Portugal
Ranger Raptor 6g
This message may not appear on EU versions. I saw it on the US manual but not on mine.
Sequoia
Dan
Germany
It’s not in your manual, it’s not intended that way, so the dealer can’t repair anything. Everything is working as designed. And there is no coding for it in FORScan.
radial
Rich
Maryland
When I first got my Raptor back in August, I definitely saw that popup every time I started the truck. At some point it no longer appeared on startup. Pure speculation here, but I wonder if that was a feature that Ford killed off in the last OTA software update.
Raptortugal
Portugal
Ranger Raptor 6g
I just looked at my French manual and it clearly says that a message should appear.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Screenshot_2025-02-12-18-27-42-850_com.opera.browser
joordan
Italy
and here is the same message in italian...you can use google translate but it says what I wrote above. and it does not say the usual disclaimer of "on certain model/if equipped"
this looks like a standard feature.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Screenshot 2025-02-12 at 19.33.38
joordan
Italy
if you had and now no longer, it had been definitely removed via OTA update....
joordan
Italy
it's in my manual, see above
radial
Rich
Maryland
And it's also in the English manual:
Note: Your vehicle reverts to normal mode​
each time it is started. If you shut your​
vehicle off in a drive mode other than​
normal mode, at startup the instrument​
cluster screen displays a pop-up asking if​
you would like to return to your last used​
drive mode. If you select yes to the pop-up,​
your vehicle returns to the last selected drive​
mode and the default four-wheel driveline​
setting associated with that drive mode. If​
you select no, your vehicle remains in normal​
you do not select yes or no the pop up​
message times out, your vehicle remains in​
normal mode, and the four-wheel driveline​
setting remains in its last used setting.​
joordan
Italy
and this is from ford US manual.....
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Screenshot 2025-02-12 at 19.38.09
