HyperM3
Lawrenceville, NJ
I've got good news for everyone, I have finally figured out anti-glare high beams for 6G USDM Ranger Raptors. Remember, all changes are at your own risk, however I just got out of the truck after testing this for a half an hour. It's the real deal.
Coding is as follows:
IPMA706-01-01xxxx, xxx9, xxxx
SCCM724-04-01xxx3, xxxx
IPC720-10-01xxxx, xxx2, xxxx
HCM734-01-02x2xx, xxxx, xxxx
HCM734-01-04xxA0, D1xx
APIM7D0-09-01x1xx, xxxx, xxxx
APIM7D0-09-03xx8x, xxxx, xxxx
Remember, do NOT replace any data with an "x", only the actual digits shown. Make backups of your vehicle as always.
This was done by comparing European and Australian asbuilt dumps to the asbuilt of my truck and I used the old F150 guide for direction.
Happy New Year everybody!
(please update the spreadsheet once you test it @craigc)
Finally coded this on Sunday and tested it on the way home from work last night. Worked amazing. It was so cool watching the lights turn on and off on the sides when cars were coming. Thanks again for posting this!
Ragner
Victoria
2022 ranger XLT
Supervisor
If anyone has had trouble getting the "reverse camera at speed", this is how I got it working on MY22 XLT
IPMA 706-02-02 xxxF CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-02 Axxx xxxx xx--
APIM 7D0-01-04 xxxx FCxx xx--
APIM 7D0-02-02 xxx3 xxxx xx--
As always use at your own risk ??
Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
I have read through this thread and have not found this. Does anyone know how to enable the auto start stop on city streets. It works in traffic on the freeway, but not when driving on normal streets.
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Absolutely top-notch. It works perfectly on the European Wildtrak. Thank you very, very much!
I would like to confirm this for the spreadsheet.
Now it would be brilliant to make the front camera activatable as well.
Raptortugal
Portugal
Ranger Raptor 6g
I will try on my Raptor Euro.
For APIM 7D0-02-02 xxx3 xxxx xx--, do I add +3 to the existing number or replace it with 3 ?
Sequoia
Dan
Germany
I just had to replace the numbers. Not add!
Next question:
Does anyone know if it’s possible to reprogram the outlet in the truck bed so that it has a shut-off time of about 30 minutes?
jrRaptor
Maize, KS
It is always enabled unless you shut it off and should work on normal streets. Could be your accessories are pulling too much power for it to shut off, especially with colder weather.
Antman450
Anthony
Reno, NV
OH I should have said it more clearly. I now realize that saying start stop confused it with the engine starting and stopping.
I am referring the the Auto Resume with Radar Cruise Control. When I am using adaptive cruise, on freeways when the truck comes to a stop in bumper to bumper traffic, it will start again once the car in front moves. On normal streets this does not happen. I think it may also be called traffic jam assist by other manufacturers.
It is like the truck knows you are on a freeway and automatically goes into Auto Resume mode for adaptive cruise control. Then when the car in front moves, it start to accelerate from a stop automatically. But, when on normal streets, it knows and when it comes to a stop it goes to Auto Stop and you have to either press the gas or kit OK on the steering wheel to have the truck start again when the car in front start to move.
Ragner
Victoria
2022 ranger XLT
Supervisor
Replacing the 2 with the 3 gets rid of the "full view not available"
Raptortugal
Portugal
Ranger Raptor 6g
Thanks for the tip, it works; useless therefore essential ?
Thanks also, on the other hand I have a new button that appeared, the CAMERA AUX. When I press it nothing happens (does it work for you?)
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_20250228_210709_1
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_20250228_181237
HyperM3
Lawrenceville, NJ
Can someone remind me where to find the codes for enabling the actual numerical temp for engine and oil in the dash display?
Ragner
Victoria
2022 ranger XLT
Supervisor
Mine also, I believe it is something to do with an auxiliary camera for a caravan. Unsure if it works or not.
