Sequoia
Dan
Germany
Ranger Wildtrak 2023
The only thing I’d really still like to have is the 12″ screen as the instrument cluster. But €1,500 is really too much for me.
Kossibeibe
Finland
Ford ranger 2024 EU tremor
If you have correct apim then it's just the screen, but if ampin needs to be changed then it's both, you won't need anything else for screen.
Okey 2 wires, molex mini50 3 pin for power and had with power wires to Data transfer between apin and screen
Sequoia
Dan
Germany
It should be easy to swap, as was also described here in the forum. There is a own thread for that.
renato23
Renato
Brazil
Ranger Black 2.0
It has been a while since I posted here. Had a problem with my scanner and had to buy a new one.
Now i'm trying to activate the rear camera at speed. Does anyone with just the rear camera was able to do it? I have a feeling it only works with the 360 camera system.
I was able to enable this icon at APIM module, but when I click it nothing happens.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1749425553739-ex
I'm also wondering if there's a way to activate Alexa. At APIM module I enabled it but can't find it anywhere. Any ideas?
Artur
Brazil
Nextgen Range v6
Engenier
hey guys. how I do to show temp on my 2024 ranger XLT? Like this...
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1749597316454-gz
renato23
Renato
Brazil
Ranger Black 2.0
Me and @diogomt already made some tests. Our car don't have digital ar conditioner, so you won't be able to control the temperature.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
a77cj7
Sturgis, SD
98 Ranger
Does anybody have a plain text option for pcm? I only see the as-built version.
I need to change my fuel tank size.
If its not on the spreadsheet, no. But you can go through each module and see if anything pops out at you
renato23
Renato
Brazil
Ranger Black 2.0
I updated my turning front lights to stay on with DRL and position, not just turn. Now they are on all the time but I got a problem: when my headlights are off and I switch the turn lever, the side i'm turning to blinks like it should but when I got my headlights on the turning light won't blink at all. Any ideas what is might be?
Davo_fn
Spain
Hi guys,
seeing some random videos, I found this:
This guy says when he uses the blink with a trailer, the screen shows a lateral camera. Is it works in every Ranger Raptor in trailer mode? do you know if it could be activated always? looks interesting.
thanks
Sequoia
Dan
Germany
I activated it but it does not work on my Wildtrak ?
You probably need those cameras in the mirrors or something. I know my one tailgate camera wont do side shots
Sequoia
Dan
Germany
I have them (Wildtrak!). I can activate it manually since I coded it. There is a button now. But it does not come on when blinking
