Sequoia
Dan
Germany
Ranger Wildtrak 2023
This i would love to turn off as well. Just this. Not the tone.
alrashid2
PA
Hey guys, happy to be here! This spreadsheet is awesome.
Do any of you know of a general guide for getting setup on how to use FORScan before I jump into doing all of this?
Also, do I have to buy this specific OBDLink brand cord or will one of the generics work?
Thanks guys!
alrashid2
PA
Also, looks like the Auto Stop Start is listed on the CONFIRMED tab - is that true? Other forum posts here on the forum are saying that it adds a bunch of lights to the dash...
and what does this mean: (only affects cluster visibility/nag)
It takes the autostart symbol off the dash cluster and stops it from popping up in the cluater when you start the truck, only. Doesnt disable auto start
alrashid2
PA
Oh I understand now! Thank you for explaining that
fastlane
indiana
26 ranger xlt
Just chiming in here to say thanks for all The work on this resource.
I recently sold off my 21 f150 to downsize. Got my 26 Ranger xlt about two weeks ago. One of the first things I realized is how bad the stock stereo sounds even compared to the non-BO system in my f150. Changed out the front door speakers and tweeters….was still not happy (should have known better).
Today I set the EQ to flat with forscan and that seems to have improved things in a noticeable way.
Thanks all.
5.0ALM
Adam
Brisbane, Australia
2016 RAV4 Cruiser, 2024.50 Mustang GT Fastback
Hi all.
Have just come across from Mustang 7G, and have an MY26.5 Everest Tremor on the shopping list.
(Everest, not available in the US, is the wagon version of the Ranger)
If you weren't aware, the latest version of FORScan 2.3.71 was released a few weeks ago.
https://forscan.org/download.html
No release notes/change log yet, so not sure what has changed. :ontheloo:
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
I didn't even think to use FORScan to mess with the EQ. What settings did you change?
fastlane
indiana
26 ranger xlt
its a setting in the ACM (audio control module). Check out the tab for ACM…you’ll find it there.
it does take away the ability to toggle on the screen between “all seats” and “driver”, but the sound seems fuller overall and there is more presence in the front, making the stage feel more pronounced. It’s still not amazing, but it’s is much improved after the change.
schwartzki
NE Indiana
'24 Ranger Raptor, '23 GTI Autobahn
Noticed on 24+ F-150 and Superduty's when you select a trailer you get a trailer specific DTE on the IPC with a little trailer icon. I also noticed after a recent OTA update that my truck now says something along the lines of DTE will change when I chose my trailer but the cluster doesnt show the trailer icon and range did not change. Anyone found the settings to display that in the IPC?
landiscarrier
Landis
pocono mtns
sales
Forscan is a great tool that we as Ford owners are lucky to have access too! So far I’ve done….removed door chimes, removed “full view not available” in trailer camera view, added actually temp numbers to all fluid gauges, added temperature number to tire air pressure screen, removed check seat belt screen at start up added glare free headlight setting (that one is so cool!) and probably a few more!
If you get Forscan spend the $15 bucks for it! It helps with all the work they do on it.
Sequoia
Dan
Germany
I am confused. This is not our spreadsheet? And only as build? All of them?
landiscarrier
Landis
pocono mtns
sales
No it’s not. It’s from RR owner on YouTube. And it works. Along with adding temperature to tires along with pressure and I added temperatures to all the gauges. So now the tires say 39psi 98 degrees. And for example oil temp shows the gauge and below it says 185 degrees.
