Geiser Front/Rear Springs: +1.5" Front/+1" Rear
Locust13CT
Tom
CT
Aircraft Inspector
New Option popped up available at foutzmotorsports. Pricey for springs but kinda like the idea better than a spring perch, would just be concerned on ride quality after as the truck is still a daily. Anyone with any experience with Geiser springs?? thoughts?
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear spring pric
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear spring height 1
MidnightSpecial
2025 Raptor Ranger
From what I have read, springs will effect your ride quality quite significantly. Also, the F150 raptors have had issues with cracking the shock top mount with aftermarket springs in extreme conditions (Baja trips).
90% of us will never ride it that hard but still.
huskyfargo
Arkansas
2018 Golf R / 2024 Ranger Raptor
Has anyone added just the rear springs to account for a heavier load?
I have a decked drawer (not heavily loaded), and the rear has dropped significantly. I have a camper shell coming soon…I don’t want it to squat.
momodog
Everett
Socal
Ranger Raptor Carbonized Grey 2025
Financial Advisor
I changed to King Springs in the rear for load 400 lbs and the rear is 3.5 inch higher in the front. Im adding the front springs to change rake and load bearing that will sit closer to stock
Also photos now and before adding
Only rear springs installed.
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_4921
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_4920
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_4486
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_4636
momodog
Everett
Socal
Financial Advisor
New front King Springs installed, 128SP. Ride firm but better control. I giving up the floaty, cushy ride to be able to carry more weight.
The Ford Raptor Assault instructors told me I cannot have both ways, either keep the stock ride or install suspension components to carry the load,
if we limit the rear weight to not more than 250 lbs, the rear will squat a bit but will still get most of the factory ride.
Here are the install photos and after images.
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_5288
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_5311
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_5299
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_5310
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_5309
momodog
Everett
Socal
Financial Advisor
Once I have chance to get a tech guy to do forscan to readjust ride height zeroing, will report back if I can get close to stock feel
E40
Andy
ATL
24 Ranger Raptor NE
New "balanced" stance looks great!! :like:
momodog
Everett
Socal
Financial Advisor
john
Tucson, AZ
I had Geiser 1.25 front springs installed...terrible stiff ride. It felt like my old F250 on leaf springs. I had Geiser springs removed and replaced with 1 inch GOAT offroad strut spacers, ride is back to OEM raptor ride and performance.
momodog
Everett
Socal
Financial Advisor
wow, thanks for your feedback AZ Ranger. That’s what I found with mine, after installing Kings Springs front and back. The stance may look great and can handle the load, but the ride is not what Ford engineers designed the vehicle to perform.
i wish the manufacturer would just be honest and YouTuber as well. I haven’t try the strut spacers yet. Maybe I will try in the future front, but what will I do for the rear? I need to put something to handle the extra weight.
GreyGhost
NM
New here so I thought I would share my experience. When I picked up my 2024 RR previous owner had put the FMI 1.5" perch collar on the front, left rear factory. I drove it about a month until all my parts came in. I installed DV8 front winch bumper for a bronco and with a little welding and modification "making it wider" and adding some better mounting support, plus the 10k winch I added about 200lbs to the front. I removed perch collars and went with the 2" Goat strut spacer in the front along with their billet upper control arm (which looks incredible) and a full aluminum belly skid system the 7000-Series from Next Venture Motorsports which is partially installed also an amazing product. Though after all that work I was not pleased with the amount of lift it gave with the added weight up front so I ordered a set of the Eibach 1.5" lift springs for the front to add desired lift as well as compensate for the added weight oh and to fit 35's. As a result I am super please with the current ride height as well as the ride. Maybe the added 200lbs up front and custom bedslide in the back adds to the softness of the Eibach springs but seat of the pants I cannot tell much of a difference from factory. Very pleased with quality of ride. As you can see from picture it does ride high in the front as I have not had the time to dive into the rear yet. I am hoping the 1.5" Goat rear spacer will be enough to level it out, we will find out this weekend. Here are some pictures of what I have done.
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1849
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1859
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2019
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1306
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1305
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2023
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1860
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1307
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2022
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1921
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2016
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1855
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1304
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2014
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1858
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2018
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2024
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2021
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2015
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2017
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2020
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2013
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1920
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2001
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_1919
Ford Ranger Geiser Front/Rear Springs: +1.5" Front/+1" Rear IMG_2001 1
