Glove box soft open damper
alrashid2
PA
Just ordered! Even my base 2015 Subaru had a nice dampered glove box.
alloyz250
So Cal
2026 Ranger XLT FX4
I get it's 12 bucks, but all the youtube videos show these dampers have a S L O W movement.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
They are pretty slow. I installed one (it was like $8 when I got it) and it works, but it is a bit slower than I'd like. It can be pulled down faster if needed. I don't open the glovebox often.
alrashid2
PA
Ordered this one and it delivered today:
https://a.co/d/01JMn3zs
Like everybody else, it was excruciatingly slow.
So I pulled it out, and ran some of my AR lube on the teeth and the gear - you can see it inside if you take a look. My AR lube is basically 50/50 motor oil and brake lube.
I then pulled the dampener back and forth in my hand about 40 times
Re installed and now it works perfectly! Goldilocks: not too slow, not too fast.
got3fords
James
Central Va.
But won't it speed up when you get some weight in there?
alrashid2
PA
I mean, I don't plan on putting anything else in my glovebox. I put the same items in before I did the grease and work job, and it opened like all you guys' did: really slowly.
