Headlight Recalibration
BroncoGuy
Huntington Beach
2024 Ranger Lariat
Hey all. I’m about to add a 2.5” rough country level lift. To all that have done this. Did you need recalibrate your headlights?
Alaska Steve
Alaska
I thought I read somewhere on Fords' website that the projector headlights on the Lariat and Raptor are self-leveling. I think that's why they go through a self test every time the headlights are turned on. I could be wrong, but that's what I recall.
36Vegas
Morris
Atascadero, CA
The 2024 Ranger Raptor headlights self level every time you turn the them on. I just installed 2.5" front shock spacers. Headlights are fine
Truckin
24 Ranger
Weird that some reported yes you do need to adjust and others say no.
my 23 150 tremor auto level did not. Time will tell when my ranger gets leveled
Self levelling is for when you have a load in the bed or on the hitch so that the temporary squat doesn't make your headlights point up too high. Lifting the whole front end changes where your headlights point (just the y-axis, obviously), even after self-levelling so you should absolutely recalibrate or re-aim them so as to not blind oncoming traffic.
Truckin
24 Ranger
Can’t vouch for leveling yet but they do change while driving. We have a stoplight on a hill and while driving slow the lights should have pointed up. Nope, they lowered as I drove up, had a clean line of light shining on car in fronts trunk.
there are sensors near each shock that compensate
Alaska Steve
Alaska
The LED lights on the XL and XLT need to be adjusted after leveling or a suspension lift.
scrappyisbe
james
iowa
24 RR
Wit the auto leveling it does not need re-aimed. Mine is leveled and not adjusted. The level works off suspension height sensors so with the lift spacers the lights think the truck is "loaded" and they aim down. The only reason I could see to adjust the aim is if the truck runs out of auto down light adjustment when actually loaded with the spacers.
The way it was explained to me by a body shop owner is this: stand 30’ from someone and hold a flashlight at waist height pointing in the other person’s direction. Use a bubble level to assure that the light isn’t pointed up or down, but is indeed parallel with the floor. That person will not be blinded. Now hold that light at shoulder height and use the bubble level to assure it’s level. The other person is now blinded. The auto level in our trucks is like that bubble level, and the suspension lift is like where we hold the flashlight. Change the suspension setup and geometry and we need to repoint our headlights, while the auto level will help keep our headlights pointed where they were adjusted to despite whatever load we’re carrying.
Truckin
24 Ranger
Your manager is not correct it’s 25’
FYI, roads and shops have pitched slops for drainage so it’s rare to find a flat 25’. True way to do this is with a laser level https://www.wikihow.com/Adjust-Car-Headlights
Thanks, but he just explained that scenario to illustrate why headlight aiming and alignment are different than levelling and why changing the resting height affects aiming and alignment. He don’t suggest using the 30’ measurement to actually aim or calibrate the headlights.
harper7
Claremore Oklahoma
2024 Ranger Raptor- Velocity Blue
Mechanic
Here is the headlight aiming/adjustment check straight from the Ford Ranger manual ,pages 416-417. They appear to auto level to a setpoint set by the factory. Lifting the front to level will most likely change that setpoint by a little .
Ford Ranger Headlight Recalibration tempFileForShare_20250125-125721
Gravy Jones
GTI
Can 100% verify that a lift requires re-adjusting headlight level, even if you have auto leveling headlights. Just installed a 1.5” level on a 2026 Ranger Raptor. Chalked the headlight level against a wall from maybe 25 feet before the lift. After install, lights were probably a good eight inches above my chalk marks. Had folks flashing headlights at me for a couple of days after the install until I could adjust them down. 10 min with a Philips turned them back down to the chalk marks.
that is exactly how i do it. mark the headlight but off line on the garage door with tape before lifting. then check and adjust to the same mark after lifting.
