$Bill
Bill
Northern NV
Thanks for that info, it is useful and I had not measured it yet. I will try and remember it by 6-3-1.
I will add that when the beeping turns solid you are a foot away from an obstacle, which is too much IMHO, I wish it would not turn solid till you are 4-6" away. My Superduty didn't turn solid till about 4" and it was handy for the tight quarters I have on my property. When it turns solid at a foot, you have no idea how much more you have because the tone is solid from 1 foot to zero, so that is essentially a blind guess zone.
I also figured, as near as I can tell, that the dotted lines on the sides of the 360 bird's eye view are about 12" from the stock tires.
I definitely agree. The solid beep shouldn’t occur until 4-6” away. There’s plenty of times I want to be closer than 15”. Too bad this can’t be adjusted in Forescan.
$Bill
Bill
Northern NV
Anyone remember
I don't think the brakes will come on if you are going slow, I think that only works at higher speeds but I could be wrong
They will apply at slow speed. I was backing into a parking space the other day and the truck stopped and a warning came up with a loud noise. There were bushes behind me and an outlying branch got real close to one of the sensors.
Dean Nelson
Dean
SF Bay Area
2025 RR Shelter Green
Not useless… interesting. I’ll promptly forget, but thanks for making the effort!
Think Ford small block "351", (Cleveland or Windsor). Sure, it should be 5.5, but 5 is safe, and the numbers are not in the correct order, but that is easy enough to figure out.
I do this to remember the spark plug wiring on my Turbo Buick: HEMI/Cleveland.
dpAtlanta
dpAtlanta
Just North of Atlanta
I make it even simpler!
I just think of the cube root of 149,721,291.
bigb
Tucson
2025 Ranger 2.7
Actually I like that, I'll have to test with a cardboard box. I tested in front with a cardboard box and it did not stop.
jdmarler
Jimmy
San Antonio
Ranger Raptor 2026
IT SPECIALIST. Retired Navy
If you have the hitch ball camera. It's pretty accurate. I use it to park in garage and clearance from the door
Tom W8JI
Tom
Macon GA
2025 Ranger Lariat V6
Electrical engineer
Anyone remember
Every time I back down a driveway with flowers hanging where they can touch the bumper my Ranger throws the brake on pretty hard. I'm only going a reasonable reverse speed.
If I was going to test this I would test with a hanging sheet or cardboard.
TxArch
Midland, TX
Onyx White, 2026 Ford Ranger Lariat, 2.7L, 4WD
Architect & Business Owner... commercial projects for over 40 years.
Anyone remember the first generation curb finders?
Yep! Sometimes they were helpful... with your window rolled down! 🤣
RonM_TX
Ron
Conroe Tx
I wonder how much variation there is in the sensors between trucks. 5-3-1 may not be the same on all Rangers and model years. Also may be different depending on where the Ranger was built. When I have some free time I'll test mine and post if I find a difference.
My 2010 Escape was more like 6ft- 4ft- 6 to 9 inches.Never measured it but estimate it after sixteen years of driving it. I remember when it was red you could not walk behind the vehicle. So Ford does not have a hard standard for the distance of the markings.
kirkster89
Kirk
Saskatchewan
2025 Ranger, 2.3, fx4, Lariat
My driveway has a pretty steep part at the start. Everytime I back in it slams the breaks 🤣 mind you I'm not crawling in... I'll have to try just reversing in with no gas next time
