Is everyone running E load tires?
Gravy Jones
GTI
For those of you that have gone up in tire size, is everyone just resigned to running E’s? I want to go up to a 295/70-17, but everything is an E. Same with 305’s. And most 315’s. I don’t want to run 35’s.
For those on E’s, how much of a ride quality/gas mileage hit did you take?
I had load E 295s on mine early on.
Ride quality seemed fine, little to no change imo.
‘However.
‘Fuel milage penalty was pretty severe.
16-18 mpg on stock tires went down to 12-14mpg.
I wanted that width and after researching a lot of the actual tire specs .
‘I found the Falken AT4W is offered in a P285/70R17 same as stock size, but actual tread width spec on the p285 Falken was nearly identical in tread width spec to the load range E 295s.
I made the swap over year ago, got the look or stance I was after, got my fuel milage back, and got rid of my minor rub that had with my 295s of my +30 offset Bronco rims.
NASSTY
ME
I'm happy with my load range D Baja Boss AT. They ride slightly firmer than the stock load range C KO3's but not bad at all. When I was tire shopping I had to eliminate a few of my favorite AT's because they were only available in load range E's, the wider KO3's were load range F. 😮 I was surprised the ride was so good. When I put load range D Duratracs on my f150 Raptor the ride was a bit firmer than my current load range D's.
Gravy Jones
GTI
I could tolerate a little added firmness, but definitely would prefer not to take a 3-4 mpg hit.
usmc161
Midwest
2024 Ranger
So why do yall think you lost gpm’s? I looked at the BFG KO3 in the 295 and they only weight in at 61.4lbs….thats only like 4 more pounds than the stock 285’s.
ToraRaptor
Vancouver,BC
2018 Audi S6, soon to be 25 Ranger Raptor
Logistics
I've got 295/70 Baja Bosses getting installed today. I weighed the tires yesterday and they were 70lbs. The wheel I am putting them on is just under 20lbs but the combo will still be more than stock. I will comment on the ride once installed and driven.
usmc161
Midwest
2024 Ranger
Please do, I’m seriously considering the BFG KO3’s. I have the stock non beadlock wheels and figured that if I run the 295’s at 61-63 pounds I would still be lighter than the stock tires and beadlock wheel combination.
Weight, width, tread design, and diameter, all play a part in rolling resistance and power needed to turn them, which for many years the saying goes an eco-boost motor is either eco or boost, never both, and the more done to them that requires more boost, the worse that fuel mileage factor will be.
Mystic
Rusty
SoCal
'24 RR, '25 Explorer ST
Estimator
I'm running C load 35x12.5 Toyo OC AT3s.
I don't think C range in a 34/35 is hard to find at all...?
Pic-N-Stick
Northern Virginia, USA
Retired Firefighter
What rim are you using that is under 20 pounds?
Gravy Jones
GTI
Already mention I’m not interested in going to 35’s. There are zero 295/70-17’s that are not E’s. There are also zero 305/70’s.
You can clear a 295 or 34“ tall 11.5: wide tire on a stock +55 offset .
Even the +30 offset Bronco wheels I had my 295/70R17s on cleared everywhere but full steering lock in reverse. Even then it was only a minor rub.
Not quite the case with a 35x12.5 tire. Pretty sure that requires a lift of some kind and a little less positive different offset wheel or spacer.
Mystic
Rusty
SoCal
Estimator
" For those of you that have gone up in tire size "
You wanted to know, but you aren't actually interested in running meaningfully larger tires?
Forums are weird sometimes.
