ntbruncie
Nick
Phoenix Arizona
I know a bunch of people have wanted to do this on their rangers but with out a plug and play option out there it’s difficult. If you use the 4 wire plug at the hitch the truck freaks out and thinks a trailer is attached, gives faults for trailer tail lights not working and disables the blind spot/ cross traffic system.
I was able to get my hands on the wiring diagrams from a friend that works at a shop so I could hard wire into the tail lamp harness. If you plan on doing this modification you will find if you pull the tail lamps the harness to them is no help. All the wiring to the lamps is black wires. You need to get under the rear and out each outside of the hitch you will find a harness the you can follow up to the tail lamps I tapped in to this harness
i have attached photos of the harness diagram. Hope this helps you all out.
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) IMG_4048
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) IMG_4051
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) IMG_4196
Ford Ranger LED tailgate light bar installed (harness wiring diagram attached) IMG_4195
nice. i have one of those in the garage from a 2019 ranger. i keep thinking it would be cool on this truck
RR2025MA
taeminn
MA USA
Ranger Raptor, F-150 Lightning
Does the light bar interfere with the access hole to lower spare tire?
Reactions: Doc
Alaska Steve
Alaska
Make and model of the light bar? Is it wired to both the left and right tail lights (for turn signal operation)?
Reactions: Doc
ntbruncie
ntbruncie
Nick
Phoenix Arizona
it’s an Opt7 triple row with amber turn signals. Yes the turn signal wires are ran to each tail light harness and hard wired in.
Jeffola
Southwest Florida
Business Development
No, the access hole to lover the spare is next to the license plate.
It will interfere with the access in a Raptor, the larger tire required it to be relocated.
fordgt
Awesome, thanks for posting this. I have it in my Amazon shopping cart, did you use the magnets for mounting? Any chance you have a picture of where you tapped into the harness?
Reactions: Doc
Doc
Doc
Live oak fla
2024 STX, 2020 HPP Mustang, 2024 Subaru WRX
Nice !
Rclancy1023
Robert
Rhode Island, USA
2025 Ford Raptor Ranger
Security
Do you think this set could be the same on a 2025 Ranger Raptor?
I can not find one that will work.
Sauce
Northeast
2025 Ranger XLT FX4
Are you not using it as a backup light? Notice you didn't use that wire.
Sauce
Northeast
2025 Ranger XLT FX4
Did you tap the reverse wire too? Since it wasn't highlighted in the diagram I didn't think you used it.
I am installing reverse lights on my bumper and was planning to just tap that wire (don't need park or turn), and trying to understand the wiring better.
ntbruncie
ntbruncie
Nick
Phoenix Arizona
Yes I did tap into the reverse light wire for the bar. Sorry I didn’t high light that wire on the diagram.
