Mirror tap and Fuse tap for Detector or Dash Cam?
Fawnbuster
Indiana
Appears it may be the same 5 pin connector used on the DRL module.
Fawnbuster
Indiana
Got my Blendmount today and installed everything using one of my old mirror taps. Took a while to get the mirror shroud off and had fun with the multimeter. Talk about cramped space.
I found 12v and ground on the drivers side wiring harness shown here (the gray harness, not what my finger looks like it's pointing at):
Unplug the harness and tap wires as follows: WHITE = 12v switched, BLACK/PURPLE STRIPE = Ground.
Mirror Tap
Plug harness back in, put shroud back in place, install mirror mount (or use suction cup thingy) and enjoy noisy alerts when LEO's shoot radar guns at you unless you're in Mississippi, Virginia, or military bases.
Not sure what I'm going to do for a dash cam. There's no way 2 mirror mounts will fit.
Wondering if that power supply you tapped into can support both a radar detector and a dashcam? I dont own a dashcam yet but when i buy it I want the shock sensor for parking lots etc so it may be a moot point since you mention that the line you used is switched.
jrRaptor
Maize, KS
Probably? Dash cam's and radar detector's typically draw less than an amp each, so likely just depends how much everything else draws on that circuit. But yes, if you want to run any dash cam with a Park Mode, you'll need a different circuit. It's pretty easy to run the line above the headliner and down the A-pillar into the fuse box to a constant powered circuit using a fuse tap.
jordantii
Jordan
Tampa Bay
www.straptacademy.com
2025 RR
Ok so this was very easy. Took maybe 8 minutes to do. Just double checking everything. I have to thank whoever found the switched 12v and G. That's what made it so simple. The shroud was also cake. Thanks for the great tutorial.
And yeah, I know it's an old school detector. It's an homage to the father of radar detection.
freakshow999
Sean
Long Beach, CA, USA
2026 Ford Ranger Raptor
IT & AV Technician
I'm new here and I know this thread is old...
I just wanted to say thank you for posting this helped me out with my new Ranger Raptor I purchased last week!
I have one question just how thin is the blendmount compared to the Amazon ones that are similar? My mount is only a few millimeters thick, but it's too thick to use the rearview mirror. The mirror is no longer adjustable...
HyperM3
HyperM3
Alex
Lawrenceville, NJ
I've been using a blendmount with 4 different vehicles now. I've never had any issues with being able to maneuver the mirror.
freakshow999
Sean
Long Beach, CA, USA
IT & AV Technician
Thanks to the info on this thread installing my radar detector install went smoothly with one caveat.
That being until I get a Blendmount I'm stuck with my radar detector taking up my dashcam area. I have a mount similar to to Blendmount that I've been able to use in three different vehicles. Unfortunately my Raptor's mirror doesn't have a post to mount to. It looks like the mirror just has a ball joint with minimal space...
jrRaptor
Maize, KS
You can get a skinny blendmount in there, unfortunately only one. I custom spliced two blendmounts together so I could have both my dash cam and radar detector on the mirror. But I'll likely get a Trackform mount and move the radar detector to the dash.
PCDan1
Dan
Park City
I had a few Blendmounts from other vehicles and pieced together one that works with my Escort and cam. It sits out from the windshield a little further than I’d like, but I like that it’s pretty close to the mirror. Only took about 10 mins to get the shrouds off, wires tapped and put back together. Getting a mount to work was a pain.
PCDan1
Dan
Park City
Added a third blendmount section and now it’s in the perfect position.
FergyA
LA County, CA
'24 Ranger XLT FX4
Mech. Engineer
Appreciate you guys posting how/where you mounted the bendable rear window bracket from The Dashcam Store.
Combined that idea with a 3D printed bracket I saw someone made for a Tundra. There is a roughly 2" wide slot in the frame directly above the rear sliding window in our truck that looked like the perfect spot to hang a Viofo A229 Pro 2ch. I tested opening/closing the window with this in place a number of times, and I did not notice the glass touching or grazing the bracket at all.
It sits tight but didn't snap in place how I intended so I used a small strip of 3M VHB tape where the underside of the bracket sits on the top of the window frame. I hate rattles so hopefully this keeps it quiet.
I'll throw the model up on thingiverse if anyone is interested. It isn't the best or prettiest design, but I think it works! Printed out of PETG so I think it should last.
Did you ever end up uploading this to thingiverse? Would love to give this a go.
UpInTheAir
NA
Patience
https://www.thingiverse.com/thing:6852601
Still holding strong. I would probably modify the design if I were to do it over, but it works fine and I am too lazy. I would shorten the mount maybe 3/4" so the camera is as high up as possible but still has an unimpeded view out of the glass. I would also try to adjust the shape so the cable is more in line with the mount or even add 1 or 2 spots to clip the cable to it.
midnight270
NNJ
2025 Ranger Raptor CGM
For those who have the blendmount for the radar how far down does it put the radar? I have my dashcam mounted on the windshield and it looks like the cam would block the radar view.
I put a tape measure where the blendmount would go and you can see two inches down my dashcam is there. I wonder if there is a way to extend the mount down for the radar.
