I agree...you could skip every other row and save a considerable amount of cutting time and still have flexibility in mounting options.
How many items need a molle opening right next to each other? Just a thought....
Maybe a checkerboard pattern?
What about making these out of a resin, like plastic cutting board material? Would those be faster to cut in a CNC?
TheAvo
Tony
2025 Ranger Lariat 2.7L
One single piece, not like the ADD (Active Desert Designs) model, is a horrible design.
I think the full rows of cutouts are important, so you have maximum flexibility in mounting accessories.
TheAvo
Tony
I was going to order the builtright panel in June but if American Adventure is going to release one I will wait.
AdventureLab
AdventureLab
Brit
St George, UT
'24 RR
I 'd love for a molle panel, or another solution that gives you a bed tie down at the bottom of the bed.
The current tie downs at the rear of the bed 4" inches from the floor are idiotic when you're trying to secure a couple 2x4's etc.
We will have that in a couple of weeks. Check out the update video at this timestamp -
AdventureLab
AdventureLab
Brit
St George, UT
'24 RR
Every MOLLE bag/pouch, but probably not most hard goods.
AdventureLab
AdventureLab
Brit
St George, UT
'24 RR
The single piece panels would probably at least double the shipping price and packaging prices since they may require custom boxes.
TacticalRRT
Shane
Indiana
2025 Ford Raptor Ranger
RRT
Heres a crazy idea - what if you made one size rectangular panel that could be installed horizontally above the wheel arch, or vertically towards the tailgate (where you clear the wheel arch). Fewer skus, less tooling, cheaper, more flexibility, allow people to buy however many they need for their application rather than covering the whole bed with molle. Just need to design the mount points so that they work for the bolts at all locations. Could double (or triple it) side by side vertically for the bulkhead panel. Theres a chance it could be compatible for multiple trucks vs specific to the Ranger, if any of the mounting holes line up (or use a universal track system to mount it).
hmmm
This! I don't need an enter driver or passenger side bed in molle. Just a few pieces here or there works.
Ag3ntC00p3r
Product Manager
I see you have some Packout mounts for the rail rack system and other applications. Do you have any MOLLE to Packout plates or adapters?
Fix4Dirt
SLO County, CA
Sweet! This would be the perfect way to get the HiLift from sliding around the bed. Staying tuned to this one.
AdventureLab
AdventureLab
Brit
St George, UT
'24 RR
Won't be long. I'm finishing up the side panels now. They're turning out great! We'll have a lot of flexibility with the rear panels (Packout mounts, MOLLE/Rotopax, etc.).
Aircraft examiner
what do you use for those scans of hte bed? we have a blue light scanner at work that is big enough to do small cars but we can't use it for anything fun. right now, its just used for smaller parts and some t55 turbine engine scans
AdventureLab
AdventureLab
Brit
St George, UT
'24 RR
That's Ford's CAD data, not a scan. Turbine engine scans sounds like fun to me!
