New MBRP Black Coated Exhaust Tip
Sauce
Northeast
2025 Ranger XLT FX4
Probably 3.5 inches. I test fitted it and figured out exactly how I wanted it to sit then cut the minimal amount so that the oem exhaust wasn’t too visible inside the tip. Just used a hacksaw and didn’t need to remove any exhaust clips.
I’ve don’t a lot of mods to the truck and the exhaust tip and tinted side markers were probably the best bang for the buck visual changes I’ve made.
Descent
Phoenix
2023 Bronco
Really thought this was a joke when I first saw it. To each their own.
celtic
glenn
I get it, but I couldn't find any other exhaust tip for the ranger because of the unique size.
High temp silicone tubes, 3.5"ID off eBay. Just apply liquid detergent to exhaust and push on.
These have been on since Feb with no problem.
Ford Ranger New MBRP Black Coated Exhaust Tip IMG_1244
Ford Ranger New MBRP Black Coated Exhaust Tip IMG_1370
PowerRanger21
PowerRanger21
Emanuel
72134A4xlt
Ford Ranger XLT 2024
Educator
I wouldn't have thought to do that but now I know. Cheers.
DesertBumAZ
AZ
24 RaRaptor
InfoSec
Did you cut the OEM exhaust back to install the tip? I installed an Amazon exhaust tip on mine and cut the OEM exhaust back 3-4 inches. Woudn't expect a tip to make a difference in sound, but it definitely sounds different (better) and my theory is that its because I shortened the exhaust.
that seems like a better idea
danmoochie
dan
florida
retired Sales manager
so you are saying that adding just the tip is changing the exhaust tone/sound? I never thought that was possible?
That is really slick! Are there any differences in tubing quality, for example is this OK?: You could get two 6” covers from this….
https://www.ebay.com/itm/164961329905
Ford Ranger New MBRP Black Coated Exhaust Tip IMG_8843
Do you worry about the tips rusting due to trapped moisture? It does not look as if you drilled drain holes on the bottom. Thanks.
celtic
glenn
I would recommend the high temp silicone tubes. For the small difference in price and not having to cut it's not worth the risk.
I thought about drilling drainage holes but didn't. After 9 months there are no signs of corrosion.
That 12” one I linked to is rated to 500 degrees F. For the $10 I would save by not buying two 6” ones, I am perfectly OK with cutting it in half, and putting the “good” ends to the rear where they show.
danmoochie
dan
florida
Does anyone make a duel end in black? and if so, did it change the sound???
Sauce
Northeast
2025 Ranger XLT FX4
I don't think that throwing a tip on changes the sound. Based on my experience, the sound changes when you cut back the OEM exhaust to add a new tip. It isn't the tip that changes the noise, its shortening the exhaust. YMMV
danmoochie
dan
florida
Ok that is where my confusion came in. Seeing posts of guys adding just the tip and stating it changed the sound, but they might have left out that they cut the OEM pipe back 4-5 inches.
VictoryDaveAZ
Arizona
2025 Ford Ranger Lariat 2.7L
I didn't even think to do that but that's a brilliant idea. I might do that since it sticks out a bit.
Couldn't you simply slide it on a little further? May slightly see the tip of the original exhaust. At least no cutting and would not stick out so far.
VictoryDaveAZ
Arizona
You can also paint the stock exhaust tip with high temp paint! Did it on mine and am satisfied with the result. A lot cheaper than $134.
Ford Ranger New MBRP Black Coated Exhaust Tip 1000014554
danmoochie
dan
florida
I think I am leaning this way as well since changing the tip does nothing for sound and I don't want to cut parts off LOL.. what paint did you use? Spray can?
