Procal installed properly?
rrmichigan
Kegan
lansing
2025 ranger raptor
Hey, I know this has been posted before ( I can’t seem to find it). I had my procal installed at the dealership just after break in on my 25 RR , so this is the first time I have pushed the truck but I noticed everyone saying they are getting 24-25psi of boost, the most I have gotten is 17, and before anyone asks it has been installed for 300+ miles, my question is it installed and if so properly? Thanks in advance
got3fords
James
Central Va.
Following.
Switzguy
Minnesota
It does take some time to re-learn after the install but if you're only hitting 17psi its either bad gas causing knock or it's not installed properly. Where do you fuel up and what kind of octane are you running?
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
I assume you have the programmer? Plug it in and read the ECU version. There will be an "FP" in the middle indicating the tune is installed.
Something like SW: RB3A-FPG30A-JF
rrmichigan
Kegan
lansing
2025 ranger raptor
I’ll check the ECU version tonight when I get home, I only run 93 , even before the tune typically shell or Mobil
rrmichigan
Kegan
lansing
2025 ranger raptor
Ford Ranger Procal installed properly? IMG_1718
Switzguy
Minnesota
My guess is they didn't bother to read the instructions and just plugged it in.
You could do the flash yourself but if you want to be damn sure to keep your warranty I'd take it back and make them fix it.
AMGRAPTOR
FL
2024 Raptor Ranger
this. looks like the stock file.
rrmichigan
Kegan
lansing
2025 ranger raptor
Going to try and install the performance tune and see what happens
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Yes, that looks more correcter... :rockon:
