Q? OEM Tie Rod Charactoristics (left and right)
embedded rock
Earth
One truck, two motorcycles
Ford parts break-down shows a single part number for the inner tie rod, but the left and right tie rods have different part numbers and costs.
Ford Ranger Q? OEM Tie Rod Charactoristics (left and right) 1765032950390-tc
For those that have removed their OEM RR tie rods, the question is what is the difference between left and right tie rods? The after-market tie rods don't appear to differentiate for left and right.
Aircraft examiner
Probably juat the threads. One has to be reverse threaded so when you twist the link, the wheel moves in or out
Dhass68
Dan
Kelowna
2025 Ranger FX4 Lariat BAP
brake and Suspension tech
there will be a bend or offset in the tie rod for tire clearance on full or partial lock, should be the only difference.
embedded rock
Earth
Thanks @nate.co. I see why there are left and right outers now.
I'll have to turn to full lock and see why the outers have an elbow. I'm suspecting it's a clearance thing, but then all the aftermarket tie rods I see are straight.
embedded rock
Earth
Hey @TrevorM or @nate.co would either of you identify the threaded stub that goes into the steering rack, please? At least the diameter. Tia.
