Goldylox22
Nick
Sacramento, CA
Self-Employed
Third brake light replacement installed today from RAD Designs. Two Baja Designs S2 Sports with factory amber lens. Radio anyenna will be installed on the top.
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_9803
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_9802
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_9800
Locust13CT
Tom
CT
Aircraft Inspector
I've been looking at picking a setup like this for an antenna mount, was between the bulletproffdiesel or swarfworks ones. First time seeing this one, looks pretty good, I do kind of like the downward bed firing lights. Everything lined up pretty good? Does it seem like it will last in terms of water tightness?
do you still have the red lights for braking, too?
Goldylox22
Goldylox22
Nick
Sacramento, CA
Self-Employed
The seal they provide as part of the light looks pretty robust. It’s difficult to see in the photo since it’s pressed up against the cab pretty hard but tbh only time will tell on the effectiveness.
Goldylox22
Goldylox22
Nick
Sacramento, CA
Self-Employed
Yes, the three circular lights that aren’t illuminated are red brake lights
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Looks pretty good. Might consider something like this eventually
it definitely looks cool
dc73pdsgt
Mark
Tucson
2025 Ford Ranger XLT
looks good except for the amber lens to the rear. I want white light to illuminate the bed of the truck...
Goldylox22
Goldylox22
Nick
Sacramento, CA
Self-Employed
White light does illuminate the bed? The amber are dust lights for off-roading
Goldylox22
Goldylox22
Nick
Sacramento, CA
Self-Employed
yoopercharged
Looks good! Did they provide a harness for tying the S2s into the factory aux switches? Do the red LEDs illuminate dimmed as a running light or only when brakes are applied?
Goldylox22
Goldylox22
Nick
Sacramento, CA
Self-Employed
They provide the typical wiring you’d get from ordering them from Baja Designs. Their wiring for the brake lights is plug and play into factory.
I actually don’t know if they are on as running lights but I can check later and let you know.
adrouin64
Austin
Jay, ME
Marketing Manager
Man, I love the look of them but by the time you get the lights and strobe you're at like $850 or $1000 if you get the pro versions. That's wild.
Goldylox22
Goldylox22
Nick
Sacramento, CA
Self-Employed
It’s a $60k truck, I’ll pay $1k to not get rear ended on the trail
