Ranger Raptor - Exhaust noise through speakers?
ckibue
Charles
Africa
Other threads said it was the digit before the * for enhanced engine noise. Could it be the * is a digit for noise cancelling and the digit before is for enhanced engine noise? Wish there was a definitive answer here before I homebrew a mess.
You might be correct, been ages since I changed on my truck. Complete spreadsheet is at
Software ESE
bossy
Jerome
Bellevue, WA
Pretty clear it has, just read through the prior posts.
Read it several times. There are posts claiming there is. Others claiming there is not. I have not found a final verified answer, nor a verified forescan solution.. Maybe I'm just thick..
ckibue
Charles
Africa
I successively disabled software ESE (engine sound enhancement) on my Ranger Raptor and so has kkponolures among others.
Sauce
Northeast
2025 Ranger XLT FX4
Can you give us the instructions? A few things suggested earlier in this thread, can you confirm exactly what worked?
ckibue
Charles
Africa
First, always backup / save your current / factory settings then compare with the spreadsheet (screenshot below) and reduce by one the * digit to disable.
eg.
My as built ACM, 727-01-01 was A8FF D4FE 10B9 meaning software ESE was enabled
I changed this to A8FF D4FE 00B9 to disable it.
Ford Ranger Ranger Raptor - Exhaust noise through speakers? Screenshot 2025-05-22 at 09.16.22
Easy way to figure it out - drive the truck with the amp unplugged. Only the tweeters, if I recall, are powered by the main audio module. I doubt they produce much engine noise.
I'm more curious about noise cancelation. How well does that work in our trucks? Anyone turn it off?
Truckin
24 Ranger
Sorry if this was asked but in the sales web page for RR says this sound change allows things like quiet starts early morning or late night so not to bother neighbors or bitchy wife ?. If this is the case why would they bother with the speakers inside?
my RR is in order so can’t try, but had anyone put a db meter outside to hear the difference?
ckibue
Charles
Africa
This refers to the exhaust mode. On startup, it usually defaults to Normal which can be a bit loud with cold starts. With Quiet Start enabled, the exhaust will default to Quiet mode during the times specified. This is all set up on the multifunction screen under vehicle settings.
Truckin
24 Ranger
Gotcha. I misunderstood. So it can make outside exhaust quiet or louder. Just trying to figure out why they would pump in fake sound if the RR has its own
Johnny 5
John C
Mold maker
Just remember that in quiet start, the first 20 seconds, the exhaust valves still open and make you smile. Its a good way to know your truck started when your still in the house. My Ranger Raptor has no exhaust sound from the speakers.
Truckin
24 Ranger
Yeah, with my 23 tremor coyote 5.0 I used remote start about everytime just to hear it rumble ?
Wal
Wal
New Zealand
2022 Raptor
I'm a bit late to this thread, but I can confirm that my Aus-specced 2022 3l V6 Raptor shipped with exhaust enhancement enabled, i.e. fake engine noise piped through the speakers, despite what you might have read elsewhere.
How do I know? Aftermarket speaker and amp audio system upgrade. Select Baja exhaust mode and the noise was (subjectively) more than twice as loud as before, obnoxiously so.
I used an OBD2 USB connector with Forscan, altered the appropriate code, test drove, and the noise reverted to slightly quieter than stock.
If you're looking to do the same, what worked for me was:
ACM As built
727-01-01
Stock: ****-****-1***
Change to: ****-****-0***
