Ranger XLT Payloads
reichmaj
Jeff Reichman
St Louis
Subaru Forester
ALCON
I'm trying to assess payloads of Ranger XLT's with equipment Group 300A, 4WD, spray in bed, and Advanced tow package (67P). I'm hoping for upper 1,600's or even better lower 1,700s.
I've collected a lot of info. But driving around dealers just to snap a photo of the payload sticker is a pain. Hope this forum might provide additional info. Sales folks are generally useless.
AugPal
Augie
Chicago
Retired IBEW
Isn't it listed on the sticker when you open the drivers door?
artvarck
Art
CO
2025 XLT 4WD
Almost retired
ALCON
Not quite on target, but XLT 2.3l 4WD w/301A, regular tow package and locking diff = 1633lbs.
ryanO
Ryan
2025 RangerXLT
Sales
ALCON
You won't get to 1700. Its all about the engine choice. I have a '25 XLT with the 2.7L, 300A, spray in liner, advanced tow, and FX4 and its 1430 lbs. Go to the 2.3L and you'll gain 150 lbs or so and remove the FX4 you'll gain about 55 lbs. You can hit the low 1600 mark.
That said, if you're desperate for 100 lbs of payload you're probably overloading an axle. The total payload is also about how much each axle is carrying. On the door jam it tells you what each axle us rated to. You can't put 1200 lbs in the bed and 400 in the front seats.
ryanO
Ryan
2025 RangerXLT
Sales
Yes but you have to buy the truck or visit all trims to obtain that info.
You'll be in the low to mid 1600s as long as you choose the 2.3L. If you get a few lbs more, its a bonus.
reichmaj
Jeff Reichman
St Louis
Subaru Forester
Yes I was just hoping someone may have my desired trim. I've been collecting a lot of payload info. So I have a pretty good idea.
ryanO
Ryan
2025 RangerXLT
Sales
Are you going for the 2.3L or 2.7L?
artvarck
Art
CO
2025 XLT 4WD
Almost retired
Those Rangers and Colorado's are in 1/2-ton truck territory! So much for not getting to 1700lbs. Impressive.
2026 Ford Ranger STX
• 2.3 L Engine
• 4WD
• Trailer Tow Package
• Integrated Trailer Brake Control
• Payload 1,747 lbs
Dave8311
2025 Ford Ranger XLT
Don't exceed the tire/axle ratings and you will be fine.
The yellow door sticker is a suggestion from Ford and is not a legal document.
The GVWR sticker is the legal document.
ryanO
Ryan
2025 RangerXLT
Sales
And the axle rating is basically in line with the "payload" number. My payload sticker says 1430 but when calculated based on axle rating, its 1470. If 30 or 40 lbs makes or breaks your payload, you're in a truck thats too small for your needs IMHO.
reichmaj
Jeff Reichman
St Louis
Subaru Forester
• 2.3 L Engine
• 4WD
• Payload 1,747 lbs
the payload is right but I think there was a mistake it has to be 2WD and no integrated brake control but I don't have the vin to confirm
reichmaj
Jeff Reichman
St Louis
Subaru Forester
no truck yet just gathering info
Oregon2025Ranger
Oregon
2025 Ranger XLT RWD
2025 Ranger XLT (RWD only)
2.3 engine
Advanced Tow Package
Locking Rear Differential
Payload is 1728
I wanted it equipped it like that specifically to get a higher payload and having the advanced tow package. --XLT trim level with just two options noted above. We go camping, and in general haul stuff a lot, so wanted that higher payload.s
P.S. I have added the following which eats up 98 lbs of that 1728 payload already.
Rubber Bed Mat - 32 lbs
Tailgate liner - 4 lbs
Splash Guards - 4 lbs
All Weather Floor MAts - 13 lbs
Step Bars - 45 lbs
