Ranger XLT Payloads
reichmaj
Jeff Reichman
St Louis
Subaru Forester
2025 Ranger XLT (RWD only)
2.3 engine
Advanced Tow Package
Locking Rear Differential
Payload is 1728
I wanted it equipped it like that specifically to get a higher payload and having the advanced tow package. --XLT trim level with just two options noted above. We go camping, and in general haul stuff a lot, so wanted that higher payload.s
P.S. I have added the following which eats up 98 lbs of that 1728 payload already.
Rubber Bed Mat - 32 lbs
Tailgate liner - 4 lbs
Splash Guards - 4 lbs
All Weather Floor MAts - 13 lbs
Step Bars - 45 lbs
Ok that is helpful. No spray in bed nor 4WD?
Oregon2025Ranger
Oregon
2025 Ranger XLT RWD
Correct, no spay in bed liner and no 4WD.
I too am interested in payload capacities for various configurations. I'd like to know how much the 4WD adds to a similar configuration. Since the max payload is supposed to be above 1800, I'm assuming the tow package took off a chunk of my payload. Not sure if the locking rear diff detracts - I assume it would be minimal, but I would love to have all these numbers so folks could estimate somewhat close to what their payload should be before buying.
I took a look at the door stickers of the other three rangers on the lot -- they were all 1430 or below -- but one had the 2.7 engine and all hd the 4WD package, one was lariat, and one a raptor, so was hard to tease out what was due to trim level and what was due to engine or 4wd. But in any case, the XLT RWD with the base 2.3L engine had 300 pound more payload than the better equipped Rangers.
reichmaj
Jeff Reichman
St Louis
Subaru Forester
The attached file may help . I 'm collecting as much info as I can
Oregon2025Ranger
Oregon
2025 Ranger XLT RWD
Yes, that is a nice set of data. The payload varies quite a bit, but one should be able to tease out the weight of various options with enough examples. That spray-in bed liner seems heavier than I expected. I'll get you the exact vin number and data from the window sticker and doorsill for my 2025 if interested.
On a side note, the Tacoma is a nice off road vehicle I guess, but the reason I went with the Ranger was primarily the larger payload.
As an example, a neighbor has a nice looking 4WD 2023 Tacoma and he let me look at it. It has what looked like the same 5 foot bed as the Ranger. The payload on his sticker was 970! I didn't comment on that to him, as it is a nice looking truck and I did not want to dis it. But doing the math, if one put four people in that truck that could easily use up 700 pounds of that payload, leaving 270 pounds for the bed. Heck my wife and I are 350 pounds together (200 + 150) leaving 600 pounds, which would not be enough for our camping gear.
P.S. When trying to find out your wife's weight, mention it is purely to ensure you are within the payload capacity of your truck. Then run for your life!
artvarck
Art
CO
2025 XLT 4WD
Retired (FIRE)
Yep. Sold my ‘22 Tacoma (access cab, 6ft, Off Road) for a few reasons, and the 1150lb payload capacity was one of them.
BC_Blue
Dan
British Columbia, Canada
2024 XLT FX4
Throw on the overland rack, RTT, bumper/winch, bigger tires, rotopax/hi-lift/maxtrax and those tacos don't have much left for groceries.
As much as I'm a data nerd and fully support what you're collecting, what is your intended use case for a mid-size vs full-size? Must-have's (bed protection, hitch) vs not needed (4x4; skid plates, side steps) vs every pound possible (rear seat delete).. potentially some of the parts listings online would have weights
Between manufacturers, could compare HP/torque vs engine weights, reference set of wheels/tires vs stock
1581 lbs on a 24 XLT 301 FX4 w/ Adv Tech/Tow - the old 2.3L.
Sparkherd
Sparky
South Central Texas
1985 F-250, 2010 Ranger XLT, 2022 Bronco Badlands 7MT 2 Door
Retired USAF Weapons Integration Flight Test Engineer
F-150
Yup, grumpy wife.... Unhappy life
NM Mike
New Mexico
My 25 XLT with 300A, advanced tow package, FX4 package, BO package (with 18” wheels) and 2.7l engine is rated at 1352 lbs. I’m sure the fx4 and 18” wheels subtracts a fsir amount from the payload capacity as does the 2.7l engine.
Oregon2025Ranger
Oregon
2025 Ranger XLT RWD
My updated stats from the window sticker and door stickers
2025 XLT
2.3L
Equipment Group 300A
255/70 R17 A/T Tire
3.73 Locking RR Differential ($420)
Sport Appearance Package
Advanced Towing Package Protrailer B/UP Assist ($865)
Payload 1728 lbs
Front GAWR 2930 lbs
Rear GAWR 3570 lbs
GVWR 6050 lbs
Wallowa Ranger
Eastern Oregon, USA
I have a 2024 XLT with equipment group 300A. I also have the rear locking differential, 4x4, and advanced towing package. No spray in bedliner however. My door label says my combined weight capacity should not exceed 1644 lbs. The other door tag rates my GVWR at 6170lb, with the front being 3130lb and the rear being 3573lb.
RFC
Oregon
2025 Ford Ranger XLT
I just picked up a new 2025 XLT and am surprised (and a bit bummed) by how "low" the payload is compared to what some have posted w/FX4 and what's listed in the .pdf.
2025 XLT
2.3L
Only options:
LT255/70 R17 All Terrain OWL Tires
FX4 Package
Towing Package (basic)
Convenience Package
Mudflaps
Payload 1554 lbs
Front GAWR 3130 lbs
Rear GAWR 3570 lbs
GVWR: 6170 LBS
I can't imagine the led bed lights and 400w inverter (it's a tiny thing under the drivers seat) weigh much. I looked up the tire weight difference between the LT and P-rated tires and it's 9 lbs each (39lbs total, spare is a cheapo p-rated).
Is there some other reason the LT tires would reduce the rating? I also noticed I have a steel overload spring, not a composite one. Is that part of the FX4?
Seems weird that I've got almost 100 lbs less than this one from the spreadsheet, which is almost identically optioned, except it has running boards and I have LT tires.
2026 Ford Ranger
• 2.3L Engine
• 4WD
• Equipment Group 300A
• FX4 Off-Road Package
• Running Boards
• Trailer Tow Package (53R)
• Convenience Package
• Payload: 1,636 lbs
• VIN: 1FTER4HH6TLE25013
Oregon2025Ranger
Oregon
2025 Ranger XLT RWD
Did you have any of these items installed?
step rails, weatherproof floor mats, bed mat or liner, mud flaps, tailgate liner?
I ask as I added all of the above after I purchased my 2025 XLT. The bed mat is the rubber mat, all that adds up to o 94 pounds. So while not part of the build, if they were added at the factory, that may account for some of the lost payload capacity.
RFC
Oregon
The only option it had was the mudflaps which can't weigh more than 5 pounds.
No step rails, bed liner or mat, or anything else.
