HGHVLTS
24 Integra Type S, 65 Mustang Fastback, 71 Skyline 2000GT, 72 Celica ST
Electric System Operator
This is what I did to my truck, this is here for reference and help. I am just an enthusiast, helping others when I can. Anything you do to your vehicle is up to the owner and I am not be responsible for any problems that may come while trying to attempt this modification. This is what I did, there will/might be other ways, but I'm sharing how I did this mod.
I went on Ebay and found a set of rear headrests off of a 2019-2021 Ranger, make sure you look for the button on the side for the folding headrests.
First thing, grab your stock head rests and the folding ones, and remove the upholstery, both are held on in the same manner. there a clip that folds over itself to engage/disengage, easy to disengage.
Here is the 2019-2021, disengages where the leather meets the fabric.
The Ranger Raptor has it right in the middle and comes apart the same way.
From this point I removed the upholstery, it's a bit tight but it will come off with a little work.
I then found something that was the same size of the hole in the, happened to be a 5 Peso coin I had near by. A 19mm socket could achieve the same effect.
Next I placed the Raptor upholstery on the folding headrest, it is very tight and its a little bit of a chore to get it over the button. Once I got the leather on they button is well defined (I already completed this so don't have pics). Pull the leather very tight, enough to almost get the clip to engage. Once I had it tight and in a good place, I centered the coin on the button and traced around the coin with a pen, just enough to see the circle, I then removed the upholstery again and cut out the mark on the leather. Fold the circle in half and use a good pair of scissors to cut a small hole, then slowly work your way around.
Once again, work the Raptor leather onto the headrest and work the button into the hole, adjust as needed then reengage the clip underneath and its complete. I had both done within 45 minutes and I am aware there might be better ways to do this, however, this is how I accomplished this. Turned out well for myself and visibility is so much better.
Hope this might help anyone that is looking for a folding option and was $60 Total shipped on Ebay. Well worth it for me. Hope it helps!
ag02m5
Google
I started this but found the folding headrests I bought were a bit larger, making it really difficult to get the Raptor covers on. Wondering if some heat or something could help.
HGHVLTS
HGHVLTS
Very possible, the stock ones were very tight also, took a bit of elbow grease to finally get them onto the folding one. I didn't use heat, I was doing my best to not ruin the factory leather.
yelnoc2
Richard
Geneseo, IL
LOVE it would pay to have it done but couldn't take it on myself
jrRaptor
Maize, KS
Great write up, thanks! Another project on my to-do list. Currently, I take mine off and store them under the seat and use them when I have passengers, which is sporadic. This would be a lot easier.
HGHVLTS
HGHVLTS
Thanks, I have rear passengers very rarely also, however, I wanted to avoid taking them off in general, should have been a stock feature.
ColeTrainsRR
Cole
Minnesota
E-Tec 3
has anyone tried to find out if you could fit the center headrest in the outer 2 positions and just get a couple of those?
yoopercharged
I believe somebody did try that and the posts don't fit the outer positions. I'd go and verify right now but I'm stuck at work.
jrRaptor
Maize, KS
Correct, different spacing.
marsh1
Marsh
Houston
2024 392 Final Edition
Business owner
Just got the ones I ordered off eBay for $29ea. They are black. They don't have the colored stitching. Perfect fit. Maybe I will get around to swapping the covers but being in the back it is not really noticeable
Buckster
2025 Ranger Raptor, 2008 F150
Great Solution HGHVLTS Thanks for posting. I used the 2022-'23 Ranger folding headrests off ebay Ford Part MB3Z-21611A08-AB. $30 each ($60) delivered and HGHVLTS method works great. The folding version is a bit larger as one commenter said but take your time working the cover onto the foam headrest squeezing the foam as you go which helps. Also my '25 RR stock headrest had clear plastic over the foam so I reused that and it helps the cover slide over the foam. I didn't have pesos so I centered a quarter over the button once I had the cover where I wanted it and traced it with a fine point sharpie which worked great.
HGHVLTS
HGHVLTS
Nice find! Makes it a little easier if you don’t care about the stitching.
Thanks for posting this. I used the '21-'23 Ranger folding headrests off ebay for my 25 RR. Ford Part number MB3Z-21611A08-AB. $29 each delivered and your method works great. They are a bit larger as one commenter said but take your time working the cover onto the headrest. Also my RR stock headrest had clear plastic over the foam so I reused that and it helps the cover slide over the foam.
I did the same thing with the plastic, didn’t mention it because I wasn’t sure if all of them came that way. Glad it worked out for you!
