Rear locker and traction control
specialist_k
Kelsey
Manitoba
2025 Ford Ranger STX, 2022 Honda Odyssey EX-L, 2008 Ford F-150 FX4
Grain Farmer
I have a '25 STX with the rear locker. When I disable the AdvanceTrac, it is fully disabled and tires spin freely in the snow. But when I enable the rear locker, the AdvanceTrac lights stay on the dash but power is cut almost immediately. Any way to defeat this? I'm guessing probably would require a Forscan?
I assumed I could use the rear locker without any nanny's.
embedded rock
Earth
One truck, two motorcycles
Could you clarify "power is cut almost immediately?" Are you referring to engine power being cut [to control wheel spin]?
specialist_k
specialist_k
Kelsey
Manitoba
Grain Farmer
Yeah, like traction control is on even though it's clearly off. My guess is that it's forcing it on because a locked rear end could cause a spinout on turns in wet conditions if your not careful. Curious if anyone else has noticed this.
daytoncarter
Dayton
Yeah, it's normal. May have tried some snow donuts and discovered the same behavior.
specialist_k
specialist_k
Kelsey
Manitoba
Grain Farmer
Yeah the more I think about it, the more it makes sense.
daytoncarter
Dayton
I'm not sure it's really necessary, I mean on dry pavement there's a greater risk of damaging the diff if locked, but it is what it is.
If you want some epic snow drifts you're gonna have to pull the ABS fuse.
tomtom
Finland
2025 Ranger PHEV
First press of the traction control takes the traction control of. Then hold it to turn esc off. Make the snow fly!
daytoncarter
Dayton
I'm not sure if you read the content of the thread but traction control and stability control still function if you lock the rear diff. With it unlocked they turn off and you can slide/spin.
tomtom
Finland
2025 Ranger PHEV
Oh right, might work differently with the rear locker, thought you can definitely drift in snow without locker engaged.
specialist_k
specialist_k
Kelsey
Manitoba
Grain Farmer
Made a video to show what I mean. It's a new truck so it's fun finding all it's quark's and features.
