Rear seat back latch
Oval6G
Wayne
My rear seat back latch is not latching. When I try to to put the seat back up the parts just bang against each other. Seems like the latch is sprung closed. Any ideas how to fix it?
Ford Ranger Rear seat back latch IMG_9949
Ford Ranger Rear seat back latch IMG_9948
Ag3ntC00p3r
Product Manager
Try pulling up or removing your rear passenger headrest. If that works I believe the latch position has to be adjusted.
BroncoGuy
Huntington Beach
2024 Ranger Lariat
I had the same problem. I tried pulling the latch and shutting it. Didn’t work. Slammed it had and it shut.
jjplus5
banker
Mine was like that as well. Have to slam the seat back to get it to lock. I was just pushing it like my old truck and that don't work.
Tom catino
Tom
New Jersey
2024 ranger lariat
Machinest
My Latch had to be replaced from the factory
Awirez
2024 Highlander
It's hard to tell but it looks like there's a signature of the latch contacting to one extreme of the opening tolerance, likely hitting the catch housing. Presumably, there should be some ability to adjust the latch. You could barely loosen the fasteners to allow it to move when closing, then reopen and it should have shifted, then retighten. It may only need a minor adjustment. If you're not comfortable have your dealer do it.
Ford Ranger Rear seat back latch 1738332030901-e0
Satex
Blake
San Antonio
2024 Ranger 2.7 Ecoboost
I understand what you're asking, but isn't that a warranty issue? I get that simple fixes are more convenient than a dealer trip, but I'm guessing that's covered.
fdn266
Ontario, Canada
2024 Ford Ranger 4x4 XLT
I had the similar issue when I picked up my 24' Ranger last July........I had to really slam it to latch on.
gmarcucio
Glenn
Upstate New York
24 Toyota GR Supra MT, 24 Corvette Z06, 24 Ford Ranger XLT, 22 Mini Cooper SE
Retired High School Auto Tech Teacher
I had the same issue with my 24 XLT. I tried everything. I removed the striker and added shims to it, repositioned it, tried putting headrests to the highest position, slammed it, and nothing worked. Then I figured it out. If you hold your hand on the front of the back seat cushion right where the latch is located on the back and slam the seat back while at the same time pushing hard on the seat where the latch is, it will latch. Without pushing in on the cushion where the latch is as you try to close it, the latch just bounces off the striker. The latch needs to be pushed into the striker at the same time as closing it because the seat back is so light and flimsey it doesn't have enough weight to trigger the latch, it just bounces off of it. Nothing more than just a poor design.
RANGER/HOBB
THE WORLD
Retired USAF
Anyone tried lubrication first?🇺🇸
T-Rev
Definitely should be covered under warranty. Mine was including the damage to the seat back. Mine now closes normally. I don't have to do anything special like gmarcucio is suggesting.
