Reconfigure AUX switches for Australian High Beam Setup?
sikedsyko
24 RRaptor, 05 Z4
I was wondering if anyone knows if its possible to reconfigure the Auxilary switch fuse box on US Rangers to work similar to the way the Australian version works, where switches 5/6 are tied into the high beam circuit? Do wiring diagrams for these Auxilary boxes exist on the internet yet?
joordan
Italy
ranger wildtrak 2023
there is an high beam footwell connector that can be used for that. however that exists only if you have the level 2 lights (LED). if you have matrix LED or standard bulb, then you probably have to piggyback
DeanDeneweth
Belgium
2024 Ford Ranger Raptor EU spec
I've found this on facebook, haven't tried myself yet.
Only AUS rangers have this functions, rest of the world doesn't because of legislation.
Ford Ranger Reconfigure AUX switches for Australian High Beam Setup? WhatsApp Image 2025-04-16 at 15.38.27
Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
I tried everything I could think of, but found no way to do this. I ended using a canbus adapter that plugs into the ODBII port and send a signal to a relay to power on my lights. The cool thing is that it does many vehicle functions. I used it for the high beams and added another relay to work on the backup lights. You can control 2 things with 1 relay and you can add more relays if you want.
https://www.xbb.se/en/xbb-dongle-xbb-powerunit/
dsmclark
Sam
Dorset
Ford Ranger Raptor
I just did this and confirms it works. Here is my temporary set up to test it. This is on a uk spec tho
Ford Ranger Reconfigure AUX switches for Australian High Beam Setup? IMG_0621
Stumpm2
Wyoming
Ranger Raptor, F350 Tremor
Nice work. What tool did you use to unpin?
dsmclark
Sam
Dorset
Ford Ranger Raptor
Just used a small flat head terminal screwdriver. I was only really going out there to have a look. All comes apart really easily
