Redundant lighting wiring solution so that the Rangers do not think it has trailer behind it?
LABikeWrench
Tanner
Agoura Hills, CA
24 RRaptor (Azure)
Awesome!
So just to be sure, they do understand the goal at hand is to power redundant lighting without triggering the auto trailer detection system that shuts down all the safety sensors.
There are kits out there to run redundant lighting, I am running my lights with one now, but it powers off trailer plugs wiring and taps in on the back of the bumper plug, triggering the auto trailer detection system and shutting off all my safety sensors which I have to OK to clear my info screen every time I start the truck.
I programed in a trailer profile for my head arch rack lights in order to get my Blind side monitor system back on, I programed in a 3ft long trailer to get them to work as much like normal as possible.
This solution will allow you, with a T Harness. Take power and signals from the main vehicle harness (that powers rear tail lights) to control everything to avoid any issue with the Trailer Sensing system. Don’t worry I’m with ya. You’ll have all your BLIS and full range of safety sensors with this setup.
Awesome!
ā€˜Perfect!
ā€˜Thank you!
I am really looking forward to having everything working again.
Working with one of the main guys over there right now. I should have something to test here hopefully in the next few weeks. I will mention that someone else would want this as well, maybe that will bump it in priority for them
Clarify, this base kit would power a low amp LED third brake light strip WITHOUT using an Upfitters switch?
I would be OK with the basic kit to operate my Go Fast Camper Topper third brake light, but I would much prefer to have a more sophisticated kit with a larger connector (rather than bare wires) that has the extra additional outputs in case I want to hook up extra rear lights on the truck bumper or on the Topper itself (which would be operated with one Upfitter switch circuit). I have been considering the Leer 300200 kit, but I am suspicious that it won’t work on the Ranger Raptor ….
Thanks for pursuing this! Following!!!
Ford Ranger Redundant lighting wiring solution so that the Rangers do not think it has trailer behind it? IMG_8835
BradleyC
Bradley
North Mississippi
26 Ranger Raptor
Investigator
I ordered one of the kits, I will let you know how it works out. It does have the Ranger Raptor listed.
Did that kit that was being discussed Jan 25 every come to be available?
Still needing a simple solution for brake, tail, turn and backup light functions.
One that does not trigger the trailer detection software.
BradleyC
Bradley
North Mississippi
26 Ranger Raptor
Investigator
I dont know. I ordered a wiring harness from spv and it is supposed to be here tomorrow. My topper should be in and installed this week, so I'm planning on working on the third brake light this weekend and will post afterwards.
BradleyC
Bradley
North Mississippi
26 Ranger Raptor
Investigator
So I installed my wiring harness from Specialty Parts on the right-side brake/taillight. Remove the two 10mm bolts that hold the brake/taillight on, and you might have to kind of bump it outward with the palm of your hand but then it just pulls out. Unplug the taillight wiring and plug their harness in and plug the other end into the harness. It has a long cord attached that has a red and white wire. The white wire attaches to the positive on your third brake light and connect the third brake light ground to a ground. Works great, no false trailer alerts. I am not sure about the red wire maybe it's for a running light.
