Replacing the air filter
KevR
Kev
AZ
24 Ranger Raptor in AGM
Is this a pain for anyone else? Im sure it's supposed to slide under in the back and I struggle to get it secured by how little play and the stupid washer fluid in the way..
Ford Ranger Replacing the air filter 20250829_172140
KevR
Kev
AZ
Ford Ranger Replacing the air filter 20250829_172742
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
Nope. I even jamed a second battery in there. I went in blind, hiping the Australian kit would fit my canadian ranger. but it is one the first ones as part of ford globalization plan. 1 model worldwide, with slight regional differences, Ie: LHD, vs RHD regions.
but your air box looks to be ontop of your coolant reservoir. mine has a whole second truck battery, and i can still open mine and close it no issues
Ford Ranger Replacing the air filter 20250713_143152
Ford Ranger Replacing the air filter 20250713_143142
Ford Ranger Replacing the air filter 20250713_164625
Ford Ranger Replacing the air filter 20250723_183137
Ford Ranger Replacing the air filter Screenshot_20250829_220525_Snapchat
KevR
Kev
AZ
Looking for someone with a Ranger Raptor that can confirm. Im 99% sure it isn't secured right. The back side lifts up too easily
KevR
Kev
AZ
Mine was simple to replace
I found it simple the first time but now Im thinking the back part isnt in all the way
RaptorME
Maine
Easy, I replaced mine when brand new with a BCM. You just have to undo the air flow sensor behind the airbox. I forgot to plug mine back in though and got a CEL.😂
ShadowDragon24
2025 Ranger XLT Fx4
I did not think the air filter was different compared to my 2.3 I4 and the 2.7 V6... wow figured it was same as the 2.7 it also being a v6.
Ford Ranger Replacing the air filter Screenshot_20250830_091416_Adobe Acrobat
Shadow Black Ranger Rapto
St. Louis, MO
I found it difficult to remove and definitely had to disconnect sensor wire.
Replacing cover was also a challenge getting tabs fully seated so clamps could snap shut.
Hoping second time will go better…
RaptorME
Maine
I only lifted the cover mine, barely, enough to swap filters. Removing does seem like a PITA if needed.
