RIVAL 4x4
RIVAL 4x4
Houston TX
Looks very neat - among the best looking RR bars I have seen.
Can you share the weight of the bar including winch mount?
around 100 lbs full set
CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
So around 45kg including winch mount - that is great!
Will I be able to purchase this locally in Australia or do I need to import it?
If local purchase, will the bar be ADR approved in Aus?
RIVAL 4x4
RIVAL 4x4
Houston TX
In Australia we are in Brisbane as https://www.rival4x4.com.au/ and through national network of dealers. Bumpers are ADR69 and airbag compatible (we crash test them in Melbourne).These bumpers most likely will be sooner available in Australia rather than in the US.
CrustyNoodle
Peter
Mechanical Engineer
The more I look at the pictures, the more I like it. Do you have any indication on when it will be available to the market?
What we need next is a much better long range fuel tank solution... (160lt minimum ;)).
Critical Habitat
Twin Cities, MN
I like the Rival. Winch-Ready, but I'll probably never add a winch. Their skid plates and other newer products seem to be worth considering (plus they are a sponsor), when available.
Looks like more from others are being designed for the US Ranger Raptor, too.
One example - not familiar with ADD AddictiveDesertDesigns myself, though. Base price ($2,489) w/skid plate is reasonable. Not winch-capable. Add the front and side lights and it gets expensive fast. Also would need the ACC relocate kit ($190).
Instruction sheet shows basically everything one needs to know about removing the bumper (FYI).
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor ADD Bumper
jeffers
Jeffrey
Nevada
2024 Ranger FX4, Mk7 GTI
Don't talk them into raising the price. :)
Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
Rival, are any bumpers in the works for the non-Raptor Rangers? I am interested and front and rear bumpers.
BTW, I have tested and installed all the skid plates on the Ranger Lariat and they are great. The radiator, tank, Lower arm, and engine plates fit perfectly. The trans and transfer case ones fit as well, however there is no hole in the frame on NA Rangers for one of the bolts on one side like in AU. I drilled a half inch hole for the nut to go in and it works. Also, the hood struts fit as well.
Top quality stuff and looks awesome, I am very happy with them. I will post pictures soon.
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor IMG_1074
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor IMG_1073
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor IMG_1165
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor IMG_1168
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor IMG_1169
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor IMG_1170
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor IMG_1172
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor IMG_1062
RIVAL 4x4
RIVAL 4x4
Houston TX
As we know, skids and hood lifts for Ranger have been redesigned earlier, just waiting on production. Ranger Bumpers have been discontinued not long time ago to let new designs come in later this year.
Antman450
Anthony
Reno, NV
So, you are not going to be making bumpers in the future for the non-Raptor?
RIVAL 4x4
RIVAL 4x4
Houston TX
as mentioned above, it’s likely later this year (for the US).
Ford Ranger RIVAL Aluminum Bumper for Ranger Raptor 5e563b69-d28f-471f-b886-06c7f5dfdb1d
Johnny 5
John C
Mold maker
It is now on the list. After your transmission and transfer case skids. I already have your engine and fuel tank skids. I like them very much.
Side note.
After I installed the engine skid I gained .2 mpg increase. Same with the fuel tank skid. I gained .2 mpg there also.
How did it affect the oil and transmision temps?
rxv_poor
Leland
Tucson AZ
2016 Subaru Forester XT
IT
How did it affect the oil and transmission temps?
I didn't notice any significant difference. The engine was fine. The trans got a little warm when in 4 low going through technical situations (With at least the rear locker engaged.) in 104+ degree heat (116 degree is the hottest I've been off roading in). I'm going to add a bigger Aluminum trans pan for sure before the trans skid is in place and a trans cooler at some point.
Good chance of an engine oil cooler and bigger radiator at some point also. The desert heat is no joke. Stock I think it does pretty okay.
Johnny 5
John C
Mold maker
Thanks for all the info. Sure, appreciate it. I'm going to get all the skid plates for our Ranger Raptors as well. We live in Michigan and we are using ours for everyday driving and taking them in State Forests a few times a year in northern Michigan and our Upper Penisula. Nothing extreme like you but I would get all the plates even if I didn't go off road at all. I don't like how everything is so exposed underneath. I will definitely look into engine and transmission oil coolers as well. Not a bad investment at all! Thank you my friend....
