Rocker Panel Tape?
T-Wrecks
Mark
Roberts, WI
25 XLT FX4
Seeing what happened to my 2019 even with large mud flaps I want to add some paint protection to the lower part of my truck. I did a quick search and found this from Xpel that can be cut to any size. Anyone ever use this or something similar? A black section along the bottom would look really good with the Marsh Gray.
https://www.xpel.com/shop/xpel-univ...w9vtsUNHYina0AmCqKXImuuRAgtOKNn&variant=56967
i have not but it seems like it would do well enough
GLW
Missouri
My neighbor took his Bronco to the shop and had them spray bedliner material on his. Looks good and he said it has eliminated rock chips.
I found CLEAR truck bed liner and rolled it on with a short nap 3" roller. Looks great. Slight tipple.
where did you find that at? that sounds like a great option
Mikein the burg
Williamsburg, VA
2025 Ranger Raptor, 2019 Mercedes E400, 2005 BMW C330i, 88 Jeep Comanche
Real Estate
Found this at Ollie's. Clear.
Ford Ranger Rocker Panel Tape? IMG_5268
i think ford also offers those exact ones through the dealership so from husky its probably a way better deal. i think one guy on the site has these installed, though
Right, they are the same ones. So get them directly from Husky and save $50 - $60.
ifi was getting them, i would. (unless you ahve ford points that lower the ones from ford enough to make it worth it)
BHunted1
Sumner County, TN
2024 Ford Raptor Ranger
Plasti-Dip works great too. Don't like it, just peel it off like a band aid.
BigAir
Montana
Did you have to sand and scuff the factory paint to get it to stick? How well is it holding up?
Mikein the burg
Williamsburg, VA
Real Estate
No Prep. Just put clean before application. Fine Roller
