RRW Wheels
Rousseb90
Pittsburgh
Had this brand on my Tacoma. I’m leaning towards them when they release the new offsets paired with a 315 tire and an RPG 2.25” level. Monoforged will drastically reduce wheel weight. Anybody else have plans for this wheel?
Ford Ranger RRW Wheels IMG_8510
Ford Ranger RRW Wheels IMG_8511
RaptorMike
Orlando
I work too hard
Was thinking of reducing some unsprung weight but wanted to keep the same wheel size. Do you or anyone know how much the oem non bead lock wheels weigh? These look nice. Definitely post pics!
Rousseb90
Rousseb90
Pittsburgh
32.05lbs is what I read.
NASSTY
ME
I'm not crazy about that particular wheel but I'd be interested to see what other styles RRW has.
Slyder
Washington
KTM 1290R, '24 Ranger Raptor
Machinist
v8 goat
North Texas
The non-beadlock wheels weigh about 28 lbs each. The beadlock wheels weigh about 37 lbs each.
I just put on some RTR EVO 6 wheels that are 17x9 +30 (they also offer 0 offset). Those were 22 lbs each. I went with the Good Year Territory MT (Bronco Sasquatch tire) in a 315/70/17 (54 lbs each).
In total, I went from 94 lbs (stock BFG and beadlock) to 76 lbs.
RaptrJr
FL
I ordered some wheels from their monoforged pre-order. But not the wheels from OP
Rousseb90
Rousseb90
Pittsburgh
Which ones did you pre order?
Jabberwocky
Austin, TX
'24 Raptor Ranger, '17 BMW 328d Sport Tour
Slyder
Washington
Machinist
I'm really liking this version of the wheels. I assume if I would want these to fit the stock K03's I would need to go with the 0 offset, correct?
Yeah, the 0 offset is the one you want.
The -12 will also work, but it will push the edge of the tire past the outside of the fender flare giving you 'poke' (which some States have laws regarding how much, if any, is allowed).
I'm not a fan of 'poke', plus my State has laws regarding it, so I tend to look for wheels with 0 offset max.
I'll be going with RTR +30 Evo6's once they come back in stock.
Jabberwocky
Austin, TX
Good to know, thank you. I'm kinda new to the truck world. I also don't like the poke look either. I've been eyeing the following brands RRW, 52fifteen, and the Roush Iridium wheels, since I am not a big fan of the OEM beadlock wheels. Would be nice to relieve some weight by going with lighter wheels as well.
Slyder
Washington
Machinist
I don't remember the weight of the Roush wheels, but I think they're relatively close to the factory standard Ranger Raptor wheel weight. (which I 'think' is around the 30lbs range)
The RRW wheel you like is 24lbs.
Most of 1552's offroad wheels run between 23 to 26 lbs. (I think Patrol_HD, and Analog_HD are the lightest ones)
The RTR ones I like are in the 24 to 26lb range.
Vorsteiner makes some decent wheels, but most run the 0 offset. If they're ever in stock.
Rousseb90
Rousseb90
Pittsburgh
Ordered a set of RR7-H (17x8.5r17) in a 0 offset from 88 Rotors Offroad. $249 a wheel using discount code : RRWLABORDAY
