RRW Wheels
MQZ
Central New York
22 F150 Raptor
Ordered a set of RR7-H (17x8.5r17) in a 0 offset from 88 Rotors Offroad. $249 a wheel using discount code : RRWLABORDAY
Looking at the same. Are you leveling the front or leaving stock? Changing the tire size at all??
Rousseb90
Rousseb90
Pittsburgh
I had a 2.5” Foutz perch collar installed yesterday. Trying to get an alignment done today. I will be keeping the OEM tires for now, with plans to go with a C rated 35x11.50r17 or 315/70r17 tire.
MQZ
Central New York
22 F150 Raptor
Ah...ok... was looking to puff up the stance here without a lift and trying to see what others experience is with a wider stance and slightly wider tire, not taller. So, you're going up and outward eventually. Be cool to see what it looks like at least with 0 offset.
Daweism
Austin, TX
I'm looking at these wheels, nice and clean and huge weight savings at 21.8lbs.
https://www.relationsracewheels.com...rder-rr7-s-flow-form-17x8-5-wheel-matte-black
It states its 95.1mm and hub-centric for the Ranger, however the Ranger runs at 93.1mm?
Specifications
Bolt Pattern: 6x5.5 / 6x139.7
Center Bore: 95.1mm (hub-centric for 4G Tacoma, 3G Tundra, Ranger, Bronco, GX550, Landcruiser 250)
Weight: ~21.8lbs !!!
Load Rating: 2500 lbs
Backspacing: 5.73"
Compatible with TPMS and Extended Thread (ET) Lugs
Ford Ranger RRW Wheels 1737857286831-yc
RaptrJr
FL
Specifications
Backspacing: 5.73"
I'm not running those wheels but the same specs from RRW and the hub bore works fine, it's only a couple MM
Daweism
Austin, TX
Well yeah, if it's bigger of course it will "fit" technically but it is not hub-centric. And it's not big enough to use an adaptor hub-centric centering ring. So it's technically lug-centric. But correct me if I'm wrong because I really like these wheels and want to justify being able to get these. But I'm leaning towards RTR since they are true hub-centric and engineered for Bronco/Ranger with a 93.1mm bore.
patc890
Patrick
Rockville, MD
+25 offset
Hi, I know this is an old thread but I'm looking at RRW wheels with +25 offset also. Do you have any side photos of what these look like on your Raptor? Thanks.
GLT
2024 Ford Ranger Raptor; 2022 Ford F-150 Raptor 37
I have RRW wheels with +25 offset on Falken Wildpeak RT01 35x11.50R17. Here are a few pics:
Ford Ranger RRW Wheels AQlSLlS
Ford Ranger RRW Wheels V6f5vbs
Ford Ranger RRW Wheels dhF6yS6
Ford Ranger RRW Wheels 0f2pUoZ
Ford Ranger RRW Wheels SMCUyzS
Ford Ranger RRW Wheels XayP9YB
Ford Ranger RRW Wheels h8TnY7C
patc890
Patrick
Rockville, MD
Thanks for the photos. They look great. They don't poke out too much, just right. I love the wheels. I have the Shelter Green and think they'll look great on it. Thanks again
Reactions: GLT
GLT
Agree, they will look great on shelter green, especially if you go with matte bronze wheels.
Slyder
Washington
KTM 1290R, '24 Ranger Raptor
Machinist
RRW's matte Bronze does look good with Shelter Green.
I have their +25 matte Bronze RR5-H with black billet trim ring on my Shelter Green Ranger Raptor.
I'd drop a picture, but the truck is dirty and sitting in the shade of my garage. (not the best photo conditions ?)
patc890
Patrick
Rockville, MD
It would be great when it's looking better to get a few photos of that one. I've looked at that also. Thanks.
patc890
Patrick
Rockville, MD
Another question. I'm keeping my stock tires for now so I'll need to have them switched over. Who do you guys use for that? Do most tire places do it even when the whiles are not theirs?
