Running lights wiring (behind grill) 3 piece F-150 style
Normally I come down there diving and I could wire it up for you but I going to Ecuador instead. Very easy to wire it up you just need to find the wire that is "live" when your engine is on. What did you wire all your other lights to.
CaribbeanRaptor
CaribbeanRaptor
Ron
Bonaire (Island in the Dutch Caribbean)
Ranger Raptor Next Gen 3.0LV6
Business Owner
That would be very cool, having an expert on the Island! ? You would have a lot of work! ?
The underglow I connected directly to the battery. So I can switch them on/off even if the car is not running.
The amber lights should go on and of automatically with the daytime running lights, so that's why I'm not sure which connection to use. Logically I would think to open the connection on the headlight unit and use a wire from there, but the electrical is pretty complex and I don't want to mess up.
So if someone has some experience with this and the next Gen Ranger Raptor, than some pics or video would be very helpful!
Ford Ranger Running lights wiring (behind grill) 3 piece F-150 style 20230901_210723
And these are the 3 little lights I want to add in the front grill top:
Ford Ranger Running lights wiring (behind grill) 3 piece F-150 style IMG-20230825-WA0000
ssjx7squall
Banned
Banned
Eric
Frontier
Not something I would do but looks cool!
You have the Raptor does it not have the aux power switches. I would hook it up these as it takes the guess work out of everything.
Also your underglow lights I would hook those up to one of those too.
Hooking directly to the battery will cause problems. Most manufacturers recommend you don't hook anything directly to the battery, they will have some spare studs on the fuse box under the hood.
CaribbeanRaptor
CaribbeanRaptor
Ron
Business Owner
Thanks for your input!
I've connected the hot wire to the "not used" 10 amp fuse and the cold to the battery -
Works perfectly, the 3 amber lights are on when the car is running. When the ignition is off they are off too.
The auxiliary I want to use later on when I will install the roof Led bar.
The underglow I turn on or off with a remote and/or my phone. So also when I'm outside the car.
Ford Ranger Running lights wiring (behind grill) 3 piece F-150 style 20230902_182111
Ford Ranger Running lights wiring (behind grill) 3 piece F-150 style 20230902_182136
Ivan Baez
Ivan
Queretaro
2023 ranger raptor
Harman
where did you get them?, if you can share the link it would be great
CaribbeanRaptor
CaribbeanRaptor
Ron
Business Owner
Straight from Malaysia. Delivered all the way here to Bonaire with DHL within a week.
This is the WhatsApp number of the company Millerhill Outfitters +60194480099
Oreo_Five8
California
2024 Ford Ranger Raptor (Azure Grey)
