Offsidewing
Offsidewing
Ohio
2024 Ranger XLT 2.7L
Its just tedious and there is no quick way to do it. Its not hard. Had I started with what I know now, and using my $3 self fabricated tool first (and maybe a buddy) I could knock this out in under 4 hours.
ryanO
Ryan
2025 RangerXLT
Sales
Good to know. They are Torx 15?
ryanO
Ryan
2025 RangerXLT
Sales
Yes. My "tool" that saved the day was a T-15 bit and 1/4" wrench. A 1/4" ratchet wrench would have been more efficient.
Makes sense. I was thinking of getting a flex head ratchet wrench and rhen using hot glue to hold the torx bit in place (fill the wrench with hot glue and push the bit in). Thoughts....
SoulMafia
2024 Ford Ranger XLT 4x4
Do you think something like this would work?
Ford Ranger Signature Lux DRL install on a 2024 XLT IMG_0346
Reactions: GLW
Offsidewing
Offsidewing
Ohio
Yeah, that would work. This is how I rigged up my wrench which is similar to what you are describing. I did a quick wrap around this to bind the tape to itself.
Ford Ranger Signature Lux DRL install on a 2024 XLT 20260105_160926
Offsidewing
Offsidewing
Ohio
Nope, it sucked. Not enough room to get a good purchase on it - and the screws are barely finger tight. With the horn pulled, I was literally able to pull the bottom screw and fender side screw with a bit driver in seconds. That top inside screw is in a really tight, confined space.
K_teven
Steven
Retired Diesel Engineer
Have watched a number of videos on the install and want to try it when the weather warms up a bit. Anybody have specific recommendations on brand of conversion to use?
XLTRangerRick
CT
24 Ford Ranger XLT FX4 Velocity Blue
I installed these Amber DRL last night. Not LUX but took a gamble on Amazon. If you believe it, I actually changed them out from under the hood and didn't have to do any fender/tire removal for access underneath. The things that helped were 1) being skinny and having small hands 2) luck that I didn't drop any screws or bits, 3) the tools below from Harbor Freight. The ratcheting screwdriver bit holder was worth every penny. With it I was able to remove all the screws to the point I could take them out with my fingers not to drop them. Used 1 finger on the back to hold it against the screw and the other to ratchet 1 or 2 clicks at a time. As others stated there is NOT alot of room for tools. On the R side (passenger) I removed the horn at the screw to make more room but it wasn't necessary on the L (driver) side. The first one I did was the R and it took me about 45 minutes because of the horn and wasn't sure what I could reach. The L side was faster, about 30 min. I really love the look of them and hope they last. Even if you will tackle this from the wheel well the ratchet will help alot! I tried the 1/4 box wrench and duct tape but it was too hard having to re-align the screw each tiny turn. I only used the thumbwheel ratchet with a 1/4 bit and duct tape for 1 bottom screw on driver side.
Just wanted to tell everyone that it IS possible to replace the boards from above but unless you are a skinny contortionist it's not going to be easy. Good luck to anyone else changing them!!!!
Ford Ranger Signature Lux DRL install on a 2024 XLT 1781025247712-0d
Ford Ranger Signature Lux DRL install on a 2024 XLT 1781025337814-hh
