Turn signals as DRL lights
Muffin1
Rob
NJ
Good point. But I think its something else since the turn signal blinks when switched the dial to "off" position.
Yea maybe so, i know there's only two signal wires at that plug, maybe a third would be necessary for the park to be made 'live' and that would also require a different socket.
Also i messed around yesterday with Forscan changing the amber signal's to be enabled with the white /DRL's to see what it looked like and with that setup i had no signals, that was using a dual function amber led bulb i installed that has a brighter lumen output than the amber bulbs that came stock.
I changed the Forscan setting back i didn't care for the amber white mixed look but left the led's installed as signals.
diogomt
Brazil
🇧🇷 Ranger XLT
North american version socket is different from the other markets in the world, and as far as i know, it does have 3 wires instead of 2, i saw that in a install guide from a led bulb manufacturer (picture attached)
So, here in south america PY21W/BAU15S is the bulb socket for front turn, and for north america i'm not 100% sure about it but i believe it is 7443/T20
Ford Ranger Turn signals as DRL lights Captura de tela_27-3-2025_15044_cdn.shopify.com
Muffin1
Rob
NJ
Ill will look at my socket again and try to take a pic, thanks for the info.
mugullionaire
Peter
PH
Wildtrak 4x4
Director of IT
Hello! Has anybody figured out the forscan fix for the turn signal drl override, so it still blinks on the actual turn?
renato23
Renato
Brazil
Ranger Black 2.0
how about changing the DRL color from white to orange? Did anyone do it?
EzequielArgentina
Ezequiel
Buenos Aires, Argentina
Ford Ranger T9 2024
Auditor
I like this, but I am a little concern about the lamp (normal or led) getting really hot if you keep it turned on. I am referring to the Turn light keeping on as running light.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
I haven't. but its on my list. search signaturelux here. you'll find all the info you need on it. they now have options non performance headlights down under, and the led projectors are performance)
