KayaPayaPigDog
- First Name
- Kyle
- Joined
- Mar 27, 2024
- Threads
- 18
- Messages
- 134
- Reaction score
- 332
- Location
- US
- Website
- www.youtube.com
- Vehicle(s)
- 2024 Ranger Raptor Shelter Green
- Occupation
- US Navy
Hey everyone... i want to confirm and correct a few different things about these and let you know that i will be posting a detailed install video later today when i get time to edit everything (gotta get 3.5 hours of footage of me fumbling with 3 damns screws down to something anyone would be willing to sit thru). I have seen a lot of comments about modifications being needed to install and the fact that they dont even come on when driving. first off, you have to remove one of the 3 small aluminum guide posts (about 1mm wide and 3mm long) from the heat sink... it is a solid block of aluminum shaped down to a heat sink with fins and mounting holes and a weather gasket, that's all it is so breaking one of the tabs of is a complete non issue in my opinion, you could still put the originals back on if you wanted to and they would work perfectly. As for them not functioning correctly when driving, that just isn't the case for me. I installed them at night and didn't get a chance to go through all the paces yesterday but i did drive into work today when it was full daylight outside and they were on the whole time, i could see them in the reflection of the cars in front of me at stop lights. the only time they turn off is when you put the truck in park when the headlight sensor sees daylight and the headlights themselves are off. that is the case with the white stock ones as well, nothing to do with the module, it is a function of the truck programming and i'm going to look into whether or not they can be adjusted in forscan like the fog lghts turning off when the high beams are on is a feature that can be corrected in forscan. When i put the truck back in drive, the amber running lights came right back on. hopefully this will set some poeples minds at ease. more to follow! Cheers everyone.
