Taillight removal tips?
Garaged
Usa
Ranger raptor 2024
Has anyone removed their tail lights on their 24 Ranger? Specifically I have a ranger raptor but I don't think the tail lights are different on those. Any pointers or resources on that?
Second, how do you tap into the reverse lights to trigger something like a baja design reverse kit (assume a reverse harness is available from an F150 for example but I don't know which wire to tap)?
Take the 2 torx bolts out and then pull straight back to release the clips. The reverse light should be a single wire if it's halogen like my Lariat, if it's LED than I am not positive and the LED wires are all the same color.
Garaged
Usa
Ranger raptor 2024
Thanks, is hand pulling it enough or should I be looking to use a trim tool? Maybe my mistake was trying to pull outward instead of backward.
Garaged
Usa
Ranger raptor 2024
Thanks. Got it done. But wow they made all the wires almost the same color. Wtf.
One might be slightly brown.
Ford Ranger Taillight removal tips? 1000080149
SurfRanger
Ben
Orange County, CA
2024 Ranger Raptor Azure Gray
Product Design Engineer
Unplug the connector and u can use a multimeter to find ground and power. Can have someone do reverse for u so u can see which port gets powered only when reverse is engaged. And can find ground once u find a positive (ground on a bolt or bare metal nearby for finding positive then hold the positive and search for a ground pin in the plug). I did it for my third break light on my camper but i dont have any pictures for which ones i tapped sorry.
Garaged
Usa
Ranger raptor 2024
stormrider151
joe
Atlanta Ga
2024 ranger XLT, 2018 F250 SD
Retired firefighter
I tapped mine to install a Morimoto light bar. The backup light (halogen) is separate from the other light functions and has it's own plug. I used a simple light probe to find the correct wire. I just unplugged the bulb and tested each contact. While I had it out I replaced the bulb with an LED bulb and it made a huge difference. You can also use zone lighting to test the plug.
Garaged
Usa
Ranger raptor 2024
Oh, I only saw that one connector on the taillight though! Was this on a ranger raptor or different trim?
Does zone lighting allow triggering just the reverse lights?
scuba mike
Southern Calif
Hvac Job Foreman
i have a 2025 raptor ranger and trying to figure out how to unplug the harness tried pushing in and pulling out still no luck .. any ideas pics videos thanks
kishanp35
Parsippany nj
2025 Ford Ranger, 2023 Audi RS3, 1995 Ford Ranger Turbo ls swapped
Mechanical Engineer
Thats what i need /\
