Tonneau Covers
tbalt14
Tom
IL
2022 Ford Ranger
Electronic technician
What are the advantages over a Bak-Flip?
Really a disadvantage with trifolds like the backflip is the blockage of the rear window. Can't run something long through window back into bed of truck.
Chassis N2531
TX
2024 RR, 2022 GT500
Run something long through window back into bed of truck...
OK...I wouldn't do that in the first place.
Bt_okst
BT
Ok/Colo
That's why I always install a bakflip x4s roll top. Best of both worlds, secure, easy to use, doesn't block back glass, flexible.
Chassis N2531
TX
2024 RR, 2022 GT500
That's a nice tonneau cover. The roll-up style is definitely on my radar for my RR. But the main drawback of roll up covers is that they don't have the same strength and security as some harder covers, but they still have a sleeker design and can generally give better access to your bed storage. The right decision depends on what you want for your own vehicle and which cover seems to fit your needs the best.
Rda2w
Robert
Upstate NY
I've been trying to decide between the rollup and foldup as well. Neither is a clear winner/loser for me yet. I'm wondering if there is more leakage on the X4S. It doesn't look like it has drain tubes like the MX4.
Bt_okst
BT
Ok/Colo
I've had the x4s, or its current variant, on my last 5 trucks. It's the most flexible type of top there is that is still pretty secure. I'll never have anything different.
Richard Conley
Rich
Geneseo, IL
Line-X may have their version of that roll - does this look like it might be same?? I like to get more than one "acessory" at same place to attempt to get install costs reduced a little as I am not installing anything myself. https://www.linex.com/us/line-x-of-davenport-f1327/vehicle-accessories/tonneau-covers/eclipse
Bt_okst
BT
Ok/Colo
snowmanoz
Stewart
Portsmouth, NH
Subaru Crosstrek
I've been debating this topic while waiting on the truck to arrive.
I'm keen on the Yakima OverHaul HD Rack and prefer a roll-up cover, but see photo below (borrowed from a Jeep forum) as I suspect the two are not compatible. At a min the cover might only roll up in front of the rack versus behind. Therefore I may need to run with a retractable cover, but being pretty weather proof is my concern there.
snowmanoz
Stewart
Portsmouth, NH
Subaru Crosstrek
Also.....does anyone know the dimension of bed to cabin roof, so one could figure out which rack height would work best for there needs? I found this guide in this post but it seems to not have this dimension.
danmoochie
dan
florida
retired Sales manager
food for thought, the roll up has a soft vinyl cover on it, hard to keep clean and from dry rot or discoloring in hot weather areas, like me in Florida. The tri/folds are aluminum panels, easy to clean and wont peel crack or fade. I don't put anything through my window, so don'tcare about that. Plus the rollup have issues with the felt backer peeling off. Just my .02
