Turn signals as DRL lights
MichealStuff
Michiel
Netherlands
Ford ranger raptor 3.0 2023
Hello,
I have set the turn signals as drl lights when the low beams are on i also programmed with FORScan to le them on. Only problem is when low beam is on the turn signal won’t flash anymore. It does work with low beam of.
any one able to help me solve that?
kind regards Michiel
zedder
Toni
Zambia
Ford Ranger Wildtrak 2023
Drone Specialist
I experienced the same thing. Could not get them to work when the headlights were on.
Have you figured anything out?
HyperM3
Lawrenceville, NJ
Why do you want your turn signals on all the time? Just curious. What I did was code the wink out. So the LED stayed on instead of turning off when the turn signals are applied.
DesertBumAZ
AZ
24 RaRaptor
InfoSec
It does look pretty sick, saw someone from Europe had the turn signals solid with the DRLs
HyperM3
Lawrenceville, NJ
DesertBumAZ
AZ
24 RaRaptor
InfoSec
let me see if i can find the video
Peter949
Peter
Irvine, CA
Where is the Forscan code for this? I want to try.
DesertBumAZ
AZ
24 RaRaptor
InfoSec
Left n Right Front turn lamp usage = turn and drl
luckyPad
PadThai
Thailand
Ford Ranger Next Gen 2.0L 4x2
Ford Driver
Tried this but didnt work for me. What I did is set both Left and Right front turn lamps to "DRL, Turn and Position". But turn lamps stays on and no longer blinks. Hoping someone can share the fix or the correct settings for this.
Muffin1
Rob
NJ
Could it be they are incandescent bulbs that are one filament one function type?
You would need a led that has the ability to be a 'park' and 'signal' or even a incandescent that has two filaments for both functions, i want to do this also so I'm researching bulb options.
luckyPad
PadThai
Thailand
Ford Driver
Good point. But I think its something else since the turn signal blinks when switched the dial to "off" position.
