What gear is my truck in?
Steeliegreen
Oregon City Oregon
Ford F-350 2021 and Ford Ranger 2024 XLT
rETIRED
Should my 2024 Ranger XLT have an indicator on the gauge cluster that tells me what gear the truck is in?
If there is I cannot find it. Seems crazy to have a 10 speed and no indicator.
I think if you press the + on the gearshift the display will show what gear you're in (caveat: my truck won't be built for another couple of weeks so I'm just passing on gossip I picked up in another thread).
I know the Lariat does it but unsure if the XLT does it too.
Dingus83
Oklahoma
Do you have Sport mode? That may bring it up as well?
Fix4Dirt
SLO County, CA
Steeliegreen
Oregon City Oregon
rETIRED
I tried the click + on the shifter and nothing happened.
I will put it in sport mode tomorrow and see what happens.
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
That's not right. So, the button on the shifter work like this. in manual mode, ofcourse they change the gears, but in Auto mode, when you first hit the - button, it brings up the display, then as you continue to hit the - button, the trans will lock out grears starting with 10th- 9th- 8th- 7th etc. on every - push. it will restore the gear to operatioinal with every + press, all while displaying the gears, until you reach 10, and with one more + press, the gear display goes away. then with any press of the + or - button, the gear display returns, and shows you what gear your in. If yours doesn't display, that's a error. All models work this way.
TheDo114
5th Gen 4Runner
You need to be in drive when you click the +. Doing it in reverse, neutral or park will not display anything and in sport it will behave like the post above described.
zack
2024 ranger
Yes. I have a 24 xlt and if you press + on the shifter it will display 1-10 alongside bottom of screen
Sonny McGee
Sonny
Leesburg Ga
2024 Ranger Lariat, 2019 F-250, 2017 Mustang GT/CS
Clicking + works but it goes away when you turn off the truck. So you have to hit + every time if you want it on. On my 2019 F-250 it stays on till you turn it off. Wish the ranger did too...
Deleted member 11084
Clicking "-" on the shifter while in manual mode does the job too.
