Wheel offsets for 2024+ Ranger Raptor?
Doesnt sound that bad, if not optimally what Im looking for.
That video I posted should give you a really good idea of what your looking at for stance and poke.
with the +12s.
What width are the 17"s +10s your looking at.
Those in that video are +12 with 17x9 rim.
Ie. if your wheel is 17x8 it will pull them in a 1/2 inch compared to those plus +12 in a 17x9.
or a 1/4" in further on a 17x8.5 rim then those +12 17x9s.
HyperM3
Lawrenceville, NJ
with the +12s.
Wheels im looking at are 17x8.5 and available in either 10 or -10 offset.
rwolfcastle
Does anyone happen to have the weight for each of the stock wheels on the Ranger Raptor? It would be nice to know for comparison when wheel shopping.
Edit: to clarify, I'm talking about the standard stock wheel, not the bead-lock capable ones.
Daweism
Austin, TX
bukowski_drinks
FRank
Harriburg PA
ranger raptor
I'm looking at the KMC447 17x8.5 wheel with -10 offset. It's hard for me to see how it's going to look but from i can tell it'll poke out about an inch in a half if I'm correct.  Im new to owing a truck like RR so im still trying to figure it out.
Ford Ranger Wheel offsets for 2024+ Ranger Raptor? 1777162259656-gs
Are you planning a lift ? Crash bar delete?
What tire size?
I really can’t see -11 offset ever working without a lot of other modification even with the stock tires.
That amount of poke even if clearing them could be accomplished, the back fenders are in for a serious beating . Honestly+20, +30, +35, +40 are all much better offsets for the Rangers IMO.
I run a stock 285/70R17 tire size and +30 Offset no other mods and I do clear the crash bars but not by much. Stance is flush with the wheel wells.
Daweism
Austin, TX
What tire size?
Based on my research, 0mm offset with stock tires, I found most people said no rubbing when off roading. A couple of people reported very slight rub at full lock on if you have mudflaps installed. a -10 offset would most likely be rubbing a bit off road and definitely on full lock.
