When will 2.7 V6 be available on Ford.com Build & Price?
fordtrks4ever
Perkiomenville, Pa
Yes the 2.7 is a twin turbo
My F150 currently has the 3.5 Twin turbo
I have driven a F150 2.7TT and it had plenty of power.
I would think the 2.7TT in a Ranger would give plenty of power.
Ranger#5?
GumbyDammit
nobody disputes if the 2.7 would provide plenty of power, and the same argument valid for the 2.3. The difference is whether the extra wait and cost of the 2.7 is a better value and driving experience over the lifetime ownership of your truck.
fordtrks4ever
Perkiomenville, Pa
Each of us will make that decision for our own reasons.
I personally feel the cost is worth the value and driving experience and I have waited before for what I want.
I just do not want a 2.3 4cyl in a mid size pickup. The V6 option moved my interest to the Ranger.
jdlapointe
Maine
Project Manager
That .4 liters doesn't make much difference overall. If you think about it, the 6 cylinders are actually smaller then the 4 cylinder cylinders.
fordtrks4ever
Perkiomenville, Pa
2.3 270 HP 310 Torque Bigger cyl bore, longer stroke, less displacement 24 Ranger
2.7 315 HP 400 Torque Smaller cyl bore, shorter stroke, more displacement 24 Ranger
The 2.7 has more power
fordtrks4ever
Perkiomenville, Pa
I used to have that exact same opinion. But the 2.3 completely changed my mind and I would now choose the 2.3 over the V6.
I can understand what you are saying.
The 3.5 V6 changed my mind from a V8
The turbo ecoboost engines are peppy
I had a 1986 Thunderbird turbo coupe with a 2.3 pinto engine I called a pinto on steroids.
But I still want the Ranger with the 2.7 V6
jdlapointe
Maine
Project Manager
2.3 270 HP 310 Torque Bigger cyl bore, longer stroke, less displacement 23 Ranger
Yes, of course it has slightly more, it has 2 more cylinders even though they are smaller. What I was saying is the V6 has more moving parts to fail for minor power increases. As it is the 10r60 transmission taps out at 430ft/lbs.
It just isn't needed in a truck that size unless you are towing heavy, which is where the power/lower revs is helpful. At the end of the day you get what you want, I was just stating the differences.
Ranger#5?
GumbyDammit
Consider a Frontier? Standard V6 and widely available on lots everywhere. Destination charges built into the competitive MSRP, and more standard features than 2024 Ranger. I'll get either that or the Ranger if they come out with SCab + 6' bed option before I die.
*Standard on all 2023 Frontier grades is a 310-horsepower, 3.8-liter direct-injection V6 engine, paired with a 9-speed automatic transmission. Coupled with the truck's tough frame, the powertrain helps enable a towing capacity of up to 6,720 pounds (maximum, when properly equipped).
The Frontier's strong yet efficient powertrain delivers fuel economy ratings of up to an EPA-estimated 18 mpg city and 24 mpg highway for 4x2 models. 4x4 models are rated at 17 mpg city and 22 mpg highway.*
fordtrks4ever
Perkiomenville, Pa
I understood what you meant and was not saying you were wrong. So do not take it that way.
Notice I agreed with you about the bigger piston/bore and longer stroke of the 2.3
Yes I would consider 5000 lbs. towing heavy which is why I prefer the 2.7
That is why we can both get what we want.
Yes the 2.7 may not be needed but there are those who want it.
fordtrks4ever
Perkiomenville, Pa
Ranger 5 thank you for the Frontier info but that truck just leaves me meh.
Just can not get excited about it.
Terrorbyte
Douglas
houston
2022 mustang GT PP1 6spd
Software Engineer
its a 1500 dollar option on the F150 over the standard V6 so i suspect it will be similar for the ranger.
if so... its definitely worth it. 375 ft lbs torque + 3.73 gears = properly quick.
Ranger#5?
GumbyDammit
hey, whatever works for you :rockon: In my case, I'm more focused on getting the body configuration (SCab + 6' bed) 2 WD with tow package and locking rear differential than an upgrade on the standard motor. I already have a Maverick with 2.0L Turbo AWD w/tow and it is properly quick as well - especially in Sport mode! My needs are a mid-size with ability to use as my Daily Driver in better weather months, hauling my dirt bikes to local off roading spots, camping, and occasional road trips pulling my mini toy hauler. I'll take the better MPG and 2WD that will do everything needed and am sure the 2.3L will be plenty for me.
Different strokes and all that :like:
telenerd
Laramie
I’m waiting on the 2.7 too. I’m on the dealer list to call when it comes available. They check in with me every month saying nope not available to order, we will text you next month. I’m also hoping they add push button start. It’s 2024 soon come on now.
I have the 2.7 in my 2 door Bronco. It’s an amazing engine. Plenty of power and just recently got the Ford Performance tune. It now shifts so much quicker, no turbo lag, and has more low end torque. My only concern when the Ranger releases the 2.7 it will be north of 55k by the time you build and price.
