where on earth is the AC drain line?
snowman3
us
none
Can someone post a pic of it + road map directions, cause I'm having a tough time! I saw some posts and vids that say pass side firewall. I looked with flashlights, mirror, endoscope as best I could. Nada. Crawled underneath, etc. I would look for water drips, but there aren't any. Hence my worry that it is plugged. AC has musty smell. I've seen vids that push foam into AC drain line, but gotta find it first.
USA 2024 2.3L. It has FX4 skid plates that block view from underside. Do skids have to come off?
At least I found the transmission dip stick.
Thx!
I think it will be in the center of the vehicle. Sometime drips on the exhaust so you never see it hit the ground.
bigb
Tucson
2025 Ranger 2.7
Try shutting the compressor off a minute or so before reaching your destination, it will help the evaporator dry out and help prevent odors. Switch the fan speed to high to speed up drying. Ever since they switched from R-12 the evaporators became more tightly packed with fins and as a result many vehicles suffer from mold and odor issues from the evaporators not drying out quickly. Many vehicles even have automatic programs that run the blower fan after you park the vehicle to prevent mold and odors.
scrappyisbe
james
iowa
24 RR
Thx!
It dumps on top of the transmission.
MasterCylinder
Jay
Retired, FF, CET, Mechanic
Thx!
Since your not the only one that has asked and wondered where it's hiding . I made a post with pictures on where it is, enjoy! :like:
Tony_B
Tony
Slovakia
Ford Ranger WildtrakX 2.0 biTurbo 2025
Thx!
Hi, did you notice whether condensation water from the A/C is actually dripping under your Ranger onto the ground?
I am asking because I have a 2025 Ford Ranger Wildtrak X and I am dealing with a similar smell from the ventilation/A/C system.
The A/C cools properly, but even after longer driving with the air conditioning on, I do not see any condensate dripping under the vehicle.
My authorized Ford service checked the evaporator drain and told me that the drain outlet itself is not blocked.
However, they found that the condensate does not drain freely outside the vehicle, but falls into the area above the transmission.
In my case it seems to land on the transmission cover, which has a porous felt-like material.
Because this cover is closed/flush along the sides, the water may stay trapped there instead of dripping freely down.
My concern is that repeated moisture, together with heat from the engine/transmission area, could create a good environment for bacteria, mould, bad smell and possibly corrosion.
This may explain why disinfection of the A/C only helps temporarily, but does not remove the real cause.
Could you please check or confirm whether your Ranger actually leaves A/C condensate on the ground, or whether the water disappears somewhere above the transmission area?
Ford Ranger where on earth is the AC drain line? Missing pipe on drain hol
AssolMarandy
Wins
Fargo, FL
Ford F-150
If you are not seeing water on the ground after running the A/C for a while, the drain could be blocked. On many trucks, the drain tube is on the passenger side of the firewall and can be hard to see from above.
You may need to look from underneath. The skid plate can make access harder, so removing it may help. Try running the A/C for 10 to 15 minutes and then check for any water near the passenger side.
The musty smell can also come from the evaporator case even if the drain is not blocked. If someone has a photo of the drain location on a 2024 2.3L, that would help a lot.
At least you found the transmission dipstick. That can be harder to find than the drain tube.
If your truck has dual zone climate control, the drain will be in the center, right over the transmission.
Tony_B
Tony
Slovakia
Thanks for the replies. My truck has dual zone climate control, so the center drain location over the transmission seems to match what my Ford dealer found.
Just to explain the full story: I bought my 2025 Wildtrak X in November 2025. In April 2026 I had the A/C cleaned for the first time because a bad/musty smell started appearing after using the air conditioning. Ozone cleaning did not solve the problem.
On the second service visit I told the dealer that I never see any A/C condensate dripping under the truck, even after running the A/C for more than 15 minutes. They inspected the vehicle for about an hour and told me there is no visible drain hose or elbow, because the outlet is located somewhere above the transmission area. They also said they could not properly access or inspect the outlet area with a camera without removing parts. They checked the inside of the HVAC unit, whether water was staying inside and whether the evaporator looked clean, and they said that was all OK. Then they disinfected the A/C with ozone again, but the smell came back.
On the third visit the dealer put away some parts and was able to photograph the place where the condensate exits above the transmission cover. The problem is that they could not explain where the water goes after that, or where it collects, because it does not drip freely down to the ground. They were also surprised that there is no hose or elbow to guide the condensate away.
In my opinion this is a design issue in the standard vehicle configuration. The condensate should drain freely out of the vehicle, not into a closed/hot area above the transmission cover. If water stays trapped there, especially near heat from the engine/transmission, it can become a source of bad smell, dirt buildup, bacteria/mould and possibly corrosion.
The dealer suggested that, at my cost, they could remove parts around the transmission to access the A/C drain outlet from below and see whether some hose could be fitted, and also check where the dirt and condensate are accumulating. But I do not think I should pay for that on a nearly new truck under warranty.
The smell is now most noticeable when the ventilation is ON but the A/C compressor is OFF. My suspicion is that the smell from the wet/dirty area above the transmission is coming back into the HVAC unit through the drain opening by a chimney/stack effect.
I have now filed a formal warranty complaint and I am waiting for Ford’s response. If anyone with a 2024–2026 FORD Ranger, especially with dual zone climate control, can confirm whether their A/C condensate actually drips onto the ground or disappears somewhere above the transmission, that would be very helpful.
DrIanMalcolm
Anthony
Hey, sorry you are going through this. I have a 2025 RR and can confirm that my truck drains onto the ground as expected with the AC running.
Tony_B
Tony
Slovakia
Thanks, that is very interesting information about the Raptor.
This may actually be an important difference between the Ranger Raptor and the non-Raptor models. In my case, the dealer also checked other demo Rangers, specifically Wildtrak and Platinum models, and they said those vehicles also did not show A/C condensate dripping freely onto the ground. Based on that, they tried to convince me that “all Rangers are like this”, therefore it must be normal.
But to me that is not a valid technical explanation. If the Raptor lets the condensate drain straight down, while Wildtrak / Platinum models do not, then the issue may be related to the underbody layout, transmission cover, skid plate, felt/insulation cover, or trim-specific protection parts. It does not automatically mean that it is OK.
My concern is not only that I cannot see water on the ground. My concern is that the condensate appears to exit above the transmission and then may be trapped by the porous felt-like transmission cover instead of draining freely out of the vehicle. If several non-Raptor Rangers behave the same way, that could mean several trims share the same drainage/design problem, not that the problem is acceptable.
A/C condensate should not be dumped into a closed or semi-closed hot area where it can collect dirt, stay wet, smell bad, and potentially support bacteria/mould growth or corrosion. The fact that another model version, like the Raptor, may drain directly down is actually useful because it shows that proper free drainage is possible on this platform.
It would be really helpful if other owners could check and report:
  • model/trim: Raptor, Wildtrak, Wildtrak X, Platinum, XLT, etc.
  • engine: 2.0 / 2.3 / V6 / PHEV
  • single-zone or dual-zone climate control
  • whether A/C condensate visibly drips onto the ground
  • where it drips from
  • whether there is any musty smell from the vents, especially with ventilation ON and A/C OFF
At this point I think the key question is not “is the evaporator drain hole blocked?”, but rather: after the condensate leaves the HVAC unit, does it drain freely out of the vehicle, or does it end up on/inside the transmission cover area?
Today, when leaving from work I confirmed that it does drip near the center onto the pavement. It drips on the driver's side, onto the cross over exhaust pipe. The truck was running for about 10 minutes. I'd guess that once the pipe gets hot, you won't see it hit the ground.
Cabose-1
Eli
South Texas
2024 xlt 4x2, advance tow elocker
Student
It drips on Top of the transmission. Middle of the console, real hard to see if you are not looking for it. Harder to see if you are looking for it. But in the middle about midpoi t of the transmission on top. Real weird place.
