White Item Between Cab and Truck Box
Ryno6
Ryno
Indiana
18 gt350/22 ranger tremor
I removed mine. It has 4 plastic pop rivets on the bottom. Took a yard stick and pushed them out while standing in the bed.
Rapture2423
Midwest
Out of curiosity why did you remove it if it was held in place by the plastic pop rivets? What problem were you trying to solve?
NASSTY
ME
I thought about removing mine because I live in the rust belt and I'm concerned about it getting soaked with salty water this winter and not drying out. It may freeze while I'm at work but when it is home in my semi-heated garage it will thaw but not dry.
Ryno6
Ryno
Indiana
It was in the way for my tonneau drain tube and didn’t want it back there soaking wet and probably getting moldy over time.
jrRaptor
Maize, KS
It's just there for sound deadening. No, it isn't the greatest solution but it's the cheapest option the manufacturer had. It's likely just a poly felt and shouldn't cause any issues like mold or what have you. Won't hurt to keep it, won't hurt to remove it, though you may get an increase in noise if you do, depending how sensitive your hearing is.
Rufus
NYC
Mine has it (US). April build date.
Ryno6
Ryno
Indiana
Haven’t heard an increase in noise from removing it but I haven’t had it on the interstate yet. Not sure how it would be a noise reduction piece being mounted to the bed and not the back of the cab.
jrRaptor
Maize, KS
Harmonics is a weird thing.
FossIsleBC
Victoria, BC
2024 Ford Ranger XL
Wayfaring Ranger
STL
This doesn’t appear limited to our Rangers:
https://www.f150forum.com/f118/felt-sound-proofing-back-cab-coming-off-327259/index2/
https://www.ford-trucks.com/forums/1504470-foam-insulation-falling-off-behind-cab.html
Is it possible it’s supposed to be there but should be stuck to cab with adhesive, not flapping loose?
from the images in those two links, this is a completely different thing. Those images show a felt liner that attaches at the top.
Treasurer2
Gerry
2024 Ranger XLT With FX4 Package & 2.3 Ecoboost
I am in UK.
Got my Raptor 01-March and noted the same & on drivers side.....and that is interesting as we (in UK) drive on the right hand side...you guys in the USA drive on the left.
I investigated (prior to canopy being fitted) and noted it was definitely a "proper part".
In all it has to be something specific (sound proofing) regarding drive mechanism
Scotland, my most favourite place that I ever visited! Interesting that you have it as well.
brookei
Scotland
Raptor V6
Glad you enjoyed your visit.
FYI I worked in Toronoto for a while and loved Canada....such an amazing country.
Toronto :crackup: not Toronoto at least you spelled Canada right :p and yes i joking with ya
jlanz
2024 Ford Ranger XLT
I have it to. I discovered it when I hauled a load of compost and had to wash it out. Now I am putting a tube of pipe insulation in the gap when I haul things like that. I suspect this is packaging. They probably made a mistake on the assembly line and it didn't get removed. There is at least one person on this thread that does not have it. But if there is a real part number for this I am wrong. I am just going to leave it. I like the sound deadening idea best.
olefordguy
Craig
Alabama
From what I’ve read on this forum and other places it’s a mixed bag, some dealers remove it as part of pdi process and some leave it. Never seen an official answer from ford
