HHIRAP
Keith
Hilton Head Island
2024 Ranger Raptor, 2024 Bronco Wildtrak
HHI Fire Rescue Fleet Manager, Ford Senior Master Tech 1988-2010
Fabricated some running board drain hole block off plates. It took me about 30 minutes total time to make. I made a template out of cardboard, used some scrap aluminum I had in the garage, DA sanded them and sprayed them with “Raptor” bed liner.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_4349
Ford Ranger What did you do to your Ranger Raptor Today? IMG_4350
Ford Ranger What did you do to your Ranger Raptor Today? IMG_4348
Ford Ranger What did you do to your Ranger Raptor Today? IMG_4352
Ford Ranger What did you do to your Ranger Raptor Today? IMG_4351
DaStockST
Jeremy
You want to make a set to sell?
HHIRAP
Keith
Hilton Head Island
I’m actually going to make another set out of 1/8 inch ABS textured board today and see how those look. Much cheaper than aluminum and no need to spray bed liner on them.
NASSTY
ME
I did something similar when I had my 2017 and 2020 F150 Raptors. I used a thick piece of rubber that was a mud flap from a dump truck. The first pic is from when I was trial fitting it on my 2017 Raptor.
The 2nd pic shows the inserts I run on my Ranger Raptor. They were a little pricey but they look better the home made ones I had.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_20180228_194042455
DivRanger
James
S. California
Daweism
Austin, TX
Data Analyst
Ford Ranger What did you do to your Ranger Raptor Today? {filename}
Where buy hole fill?
I had my Bronco wheel rings powder coated anthracite grey and got them back last week.
Installed them last night.
I had the Ranger rings on my Bronco rims prior.
Seen here.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_2333
These are the Bronco rings on the bronco rims
seen here.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_2334
Ford Ranger What did you do to your Ranger Raptor Today? IMG_5195
Ford Ranger What did you do to your Ranger Raptor Today? IMG_5196
Ford Ranger What did you do to your Ranger Raptor Today? IMG_5197
Ford Ranger What did you do to your Ranger Raptor Today? IMG_5198
Ford Ranger What did you do to your Ranger Raptor Today? IMG_5199
Ford Ranger What did you do to your Ranger Raptor Today? 20250517_091918
Ford Ranger What did you do to your Ranger Raptor Today? 20250517_091812
Seen here.
seen here.
I have those same tires on our CX-9, great tire. We have 65k on them and they still have 5/32 tread! Although they are more of a "light duty" road-oriented AT tire vs. the K03, but still very versatile.
Daweism
Austin, TX
Data Analyst
RTR Evo 6 17x9 30mm
Stubby Antenna
Front driver and passenger window tint
Start stop eliminator
Ford Ranger What did you do to your Ranger Raptor Today? 20250517_102322
Ford Ranger What did you do to your Ranger Raptor Today? 20250517_102315
Catalyst
Justin
Bend, OR USA
Network Engineer
RTR Evo 6 17x9 30mm
Stubby Antenna
Looks great! At times I wish the Velocity Blue one I ordered actually arrived, and when I see yours I feel it more... but I'm really happy with white too :) The RTR wheels are such a good choice for the RR!
