TractorFixer
- Thread starter
- #1
Inspired by Lake Speed Jr's YouTube video on new engine break-in, I sent a sample to be analyzed from my initial oil change at 1,117 miles. As anticipated, the copper and silicon levels were a bit high. However, the fuel dilution was higher than I expected at 1.5%, especially since I dont spend much time idling or short trips. For comparison, my '18 F150 3.5L had <0.5% after 6000 miles with similar driving conditions.
Full comments on the report:
"Like most new engines, the 2.3L EcoBoost in your Ranger is starting out with high copper and silicon levels . Both elements are almost certainly related to the normal break-in process, and they should edge closer to universal averages
with each oil change. These averages show what's typical for a mature 2.3 L EcoBoost after about 5,200 miles on the oil. Aside from copper, wear metals already look okay compared to averages. Fuel dilution was okay at only 1.5% of the sample, and a low/thin viscosity isn't cause for concern, either. No coolant was found."
I plan to do the next oil change at 5k and send another sample to be analyzied. Full report attached, thought others might find interesting as well.
See the full report: https://www.ranger6g.com/forum/attachments/oilanalysisranger-pdf.46129/
