2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES!
Lab00Rat
Deep South
2022 BL 2-Door, 2021 Ford Ranger
Although the 2024 model was not able to be flat towed - at all, the 2025 model has corrected this oversite.
The 2025 Model of the Ranger IS flat towable!!
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! 2025 Ranger Flat To
Jalbano2
J
NYC
Maverick Lariat Lux
Don't believe it yet. They are still saying that the 2024 Raptor 3.0 V6 is both direct and port injected.
Lab00Rat
Lab00Rat
Deep South
The flat-tow on the 2024 was problematic because of the braking system was incompatible. Ford changed the braking system for 2025, as expected, and it's now Flat-Tow capable.
I do not know if your comment is Raptor specific or excludes the Raptor trim, but the engine specifications for the 3.0L are included in the updated technical specifications.
The screenshot is from the Ford 2025 eSourceBook supplied form the dealership. It lines up with previous 5G models that are flat towable.
This is only for the 2025 model year. No 2024 Ranger trim is flat-towable.
SubaruRaptor
Jory
North
He is saying that because the manual and various other text for things has been wrong.
Wayfaring Ranger
STL
if i remember right, a year ago or so (right around the first launch date) someone had asked the ford engineers about this and they did say that the 2025 model would fix the flat towing issue. so this info does check out
Judgeb
California
2023 Audi Q7, 2025 Ranger Raptor
Exciting news finally. If I read the specs from Ford (thanks Lab00Rat) correctly the towing limitations of 35 mph max and 50 miles max is in an emergency situation for any Ranger, ie. 4X4 or not. That there is a different spec for 4x4 in neutral for RV towing, ie. further range and higher speeds? Anybody seen the noted RV and Trailer Towing Guide for the 2025 for any restrictions?
Wetsib
Montana
2023 Bronco Sport Badlands, 2025 Ranger Lariat, 2020 Transit 3500 HD
Lab00rat- can you provide a link to the Ford Esource book that includes the image you posted? TIA.
olefordguy
Craig
Alabama
Go look at your engine. My 3.0 only has one set of injectors.
That’s correct on the injection, a previous thread has pictures proving that’s it’s only direct injection
Lab00Rat
Lab00Rat
Deep South
This is a dealer-only publication. You can visit your local dealer and ask them to pull this information and answer any additional information you might need... like extending your car warranty.
chasc
Illinois
2024 Ranger
Do we have any idea what type of incompatibility there was with the brake system? I’m not too familiar with flat towing, but is this about a requirement that the tow vehicle braking activates the Ranger’s brakes (like trailer brakes)?
TimmyB
Nokomis, FL
21 Ranger Tremor
TimmyB
Nokomis, FL
21 Ranger Tremor
It had to do with a changed supplier of the anti-lock braking system. That supplier's software proved incompatible with Ford's software. Somehow, they were able to find a fix for the Bronco (basically same drive-train) but not the Ranger in the 24 MY. I do not know for sure if they changed suppliers or simply were able to rewrite the software. My guess is the former because if it were the latter, they could retro that to the 24 MY.
unsavory
San Diego
2020 Ram 5500, 2020 KTM 1290 SAR, 2018 Husqvarna FE501
Seriously considering ordering a 2025 because of flaw tow ability.
Heard Bronco Raptor has issues, but my buddy did it behind his RV
This was a setup I did in a prior mid size, had been eyeing the RR in 2019 when got the zr2, but wasn't avail in states yet. One will need to install a brake actuator device I didn't like perm attached thing that simulated pressing on the front brake when being towed behind When not towing and driving like a normal truck, every time you pressing the brake pedal it would move the shaft on this plunger thing. I'll get one that's more easily removable if when I get the RR Another consideration is attaching the front tow hooks I didn't buy the bison since the front was slightly different and didn't know if Id have a spot to attach the tow hoooks. Guess I need to look into what ppl are doing w regular Rangers I also had a 2017 F-150 Raptor for a bit and towed a small bumper pull toy hauler, maybe 5000lb loaded Needed to tinker w weight distro bars and their spring rates so wouldn't squat the soft suspension
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_20191003_160230686
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_20191003_160159427
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_20191003_175145163
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! PXL_20210807_002351024
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_20191001_134512606_HDR
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_20191001_134544347
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_20191002_091656291
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_20191001_184254235
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! PXL_20210626_182211779
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_20170916_183815
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! 468570100_1777839509714279_51928056645880259_n
