2026 Ranger XL "Steelies" stock rim
Cyberwiz64
Martin
South Florida
2026 Ford Ranger XL
IT
I just purchased a 2026 Ranger XL. It has the painted rims which I would call "Steelies". The rim on the steelies show "17 X 7 1/2J. I am looking at wheels.
I found wheels I like the specs are 17x8.5 6 bolt pattern should fit the Ranger. Will this wheel work with my Ranger and the existing tires?
Thank you in advance.
Ford Ranger 2026 Ranger XL  "Steelies" stock rim Showing RIM
Ford Ranger 2026 Ranger XL  "Steelies" stock rim RIM Showing Siz
Maybe? The lug pattern needs to be 6x139.7 (6x5.5”), and consider the offset in concert with the tire size you want to mount.
Cyberwiz64
Martin
South Florida
2026 Ford Ranger XL
IT
here's the specs on the ones I am looking at
  • 17" x 8.5" wide
  • 6-lug, 139.7 mm bolt circle
  • 55 mm offset
  • 177.5 mm backspacing
Bolt Pattern: 6 × 139.7 mm (or 6 × 5.5 inches)
Center Bore: 93.1 mm
Thread Pitch: M12 × 1.5
Factory Offset: +55 mm
Factory Rim Sizes: 7.5J × 17 or 8J × 18
That's stock according to googly so you will be good. .5 inch wider wheel is .25 per side
Johnnypedals
New Jersey
2025 Ford Ranger xl stx
Machinist
Cyberwiz64
Martin
South Florida
2026 Ford Ranger XL
IT
I am using the factory tires. I have to figure out the side steps because they don't stick out much. I will see what I can negotiate when I am there. Hopefully we can work out a deal
